C
Cconway
replied to the thread
What parts from a ‘77 Evinrude 85 are interchangeable with a ‘73 Evinrude 115?
I think my issue is my float height. I’m also certain that the aftermarket kits I used were trash. I got the new OEM kits in and am...
Sep 13, 2026
M
Mc Tool
reacted to
Dukedog's post
in the thread
No tach,no charging
with
Like
jus curious as ta why you don't have an oem manual for this motor???.. doin' things your self would make your life a bunch easier..... jmo.
Sep 13, 2026
Dukedog
No tach,no charging
Sep 13, 2026
S
Signon
posted the thread
V6 240 impeller issue.
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Hi. I changed my impeller. Went from a penta to a Johnson. On start up it started to heat up quickly. There wasn't a lot of water out...
Sep 13, 2026
E
eathen13
1987 evinrude 140hp E140tlcua
Ran in lake at dark and did 7/16 gap test and passed , no arching that I can see anywhere , still limited to 3000 rpms , I’m supsing...
Sep 13, 2026
E
eathen13
Sep 13, 2026
N1265
'77 Holiday Transom
where can I get the splas hwell drain tubes and do you need a special tool to install them ?
Sep 13, 2026
N1265
'77 Holiday Transom
What is the best way / tools to use to get them finishing nails out of the Transom cover without bending it all up ?
Sep 13, 2026
roscoe
reacted to
Harkonnen's post
in the thread
R/V Port Yankee construction
with
Like
By popular demand: My current BlueWave has served me well, but it’s getting uncomfortable: too much where I don’t need it, not enough...
Sep 13, 2026
M
Mc Tool
Sounds good can I just say that if your going solo ,and having a few cocktails ....have a good boarding ladder and tie yourself on...
Sep 12, 2026
H
Harkonnen
posted the thread
in
Boat Restoration, Building, and Hull Repair
Sep 12, 2026
H
Harkonnen
What's the word on the street about current Mercury models?
There isn't one, but if there is interest, sure, I'll get it going. Here it is...
Sep 12, 2026
Berdink
reacted to
Mc Tool's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
:D I been at this lark 46 years and Im still learning
Sep 12, 2026
flyingscott
Probably a tohatsu
Sep 12, 2026
Scott06
Air Trapped in Outdrive...
There will be some air in top of the outdrive which Is no issue when the drive is turning the lube will get splashed everywhere. i pump...
Sep 12, 2026
