  • Texasmark
    Texasmark replied to the thread No tach,no charging.
    Er ah.....my Mercury manual says that if the Stator yellow wires aren't connected to a circuit....rectifier and load, or...
  • Texasmark
    Texasmark reacted to boscoe99's post in the thread No tach,no charging with Like Like.
    If the motor was running at a fast idle and the two yellow wires were unloaded (not connected to the regulator) then the stator is...
  • dingbat
    dingbat reacted to alldodge's post in the thread Maybe my turn for new boat time with Like Like.
    It's mostly handling during docking, OB just don't bite like IO and then add to it hydraulic steering. Instead of 3.5 turns lock to lock...
  • alldodge
    @Scott Danforth @kenny nunez @Bt Doctur
  • J
    jlh3rd replied to the thread Servicing my trailer bearings.
    kinda hard to follow you. You bled the brakes before you cleaned out the master cylinder?...but now you want to blow out lines/calipers...
  • H
    Harkonnen replied to the thread R/V Port Yankee construction.
    One thing I learned so far is that stitch-and-glue gets uncomfortable at this hull size. Worked well enough for a 15' Tango, but three...
  • alldodge
    Just an update. Removed drive and everything looked good. Readjusted cables, took the switch out again and clean it up. Lubed...
  • alldodge
    alldodge replied to the thread Maybe my turn for new boat time.
  • S
  • Scott06
    Scott06 replied to the thread Milky oil.
    I would pressure test the block and heads to make sure they are not cracked if they are you know is exhaust or other water source. you...
  • S
    SeaRayboater95 reacted to Grub54891's post in the thread Milky oil with Like Like.
    I usually dump the oil, put in the cheapest oil you can get along with the filter. Add a half can of seafoam, run it for a couple...
  • Scott Danforth
    Scott Danforth replied to the thread V6 240 impeller issue..
    Volvo buys Johnson pumps. Did you get the correct impeller for the pump?
  • Stinnett21
    As someone who would love to trade my I/O for an outboard, just curious how much of your distaste with the chap is outboard related?
  • H
    24', semi-planing, stitch-and-glue structure. Plans call for 30-90 hp outboard, but 90 seems to give very little extra for a whole lot...
  • Grub54891
    Grub54891 replied to the thread Milky oil.
