P
Pmt133
reacted to
alldodge's post
in the thread
Maybe my turn for new boat time
with
Like
It's mostly handling during docking, OB just don't bite like IO and then add to it hydraulic steering. Instead of 3.5 turns lock to lock...
Sep 13, 2026
Texasmark
replied to the thread
No tach,no charging
Er ah.....my Mercury manual says that if the Stator yellow wires aren't connected to a circuit....rectifier and load, or...
Sep 13, 2026
Texasmark
reacted to
boscoe99's post
in the thread
No tach,no charging
with
Like
If the motor was running at a fast idle and the two yellow wires were unloaded (not connected to the regulator) then the stator is...
Sep 13, 2026
dingbat
reacted to
alldodge's post
in the thread
with
Like
Sep 13, 2026
Transom to Trim cylinder hose leak
@Scott Danforth @kenny nunez @Bt Doctur
Sep 13, 2026
J
jlh3rd
Servicing my trailer bearings
kinda hard to follow you. You bled the brakes before you cleaned out the master cylinder?...but now you want to blow out lines/calipers...
Sep 13, 2026
H
Harkonnen
R/V Port Yankee construction
One thing I learned so far is that stitch-and-glue gets uncomfortable at this hull size. Worked well enough for a 15' Tango, but three...
Sep 13, 2026
reacted to
SeaRayboater95's post
in the thread
Mercruiser stalls coming out of reverse
with
Like
Just an update. Removed drive and everything looked good. Readjusted cables, took the switch out again and clean it up. Lubed...
Sep 13, 2026
Sep 13, 2026
S
SeaRayboater95
Sep 13, 2026
Scott06
Milky oil
I would pressure test the block and heads to make sure they are not cracked if they are you know is exhaust or other water source. you...
Sep 13, 2026
S
SeaRayboater95
reacted to
Grub54891's post
in the thread
Milky oil
with
Like
I usually dump the oil, put in the cheapest oil you can get along with the filter. Add a half can of seafoam, run it for a couple...
Sep 13, 2026
V6 240 impeller issue.
Volvo buys Johnson pumps. Did you get the correct impeller for the pump?
Sep 13, 2026
Stinnett21
As someone who would love to trade my I/O for an outboard, just curious how much of your distaste with the chap is outboard related?
Sep 13, 2026
H
Harkonnen
24', semi-planing, stitch-and-glue structure. Plans call for 30-90 hp outboard, but 90 seems to give very little extra for a whole lot...
Sep 13, 2026
