Watermann
reacted to
Berdink's post
in the thread
Original 1967 Styrofoam?
with
Like
What does original Styrofoam look like in a 1967 Holiday? . .
Sep 14, 2026
S
SeaRayboater95
replied to the thread
Milky oil
Thanks, Ken
Sep 14, 2026
Milky oil
For flushing find what ever is cheapest, your not going to put the motor under load so no issue. Do agree lower weight like 10w30, could...
Sep 14, 2026
S
SeaRayboater95
Milky oil
Mornin' evrybody. Off to get some oil to fliush this motor. Is there a preferred grade to flush with. I would think a thinner grade like...
Sep 14, 2026
C
Pipe-mounted bunk bracket?
Check Eastern Marine in Delaware. They have a good selection of trailer hardware.
Sep 14, 2026
reacted to
Scott Danforth's post
in the thread
RV build quality - Rant
with
Like
I really hate Forrest River RV right now The cheesy roof joists that all busted apart The cheesy reinforcement for a cabinet...
Sep 14, 2026
Maybe my turn for new boat time
We haven't talked about that yet, they should tell me today how they want the deposit. :unsure:
Sep 14, 2026
tpenfield
Wisconsin Deer Hunting at Risk.
Closing this up, further discussion can be on Facebook.
Sep 14, 2026
redneck joe
reacted to
roscoe's post
in the thread
with
Like
MERRILL, WI (MDH) — Hundreds of Lincoln County deer stands may soon require residential building permits after inspectors discovered...
Sep 14, 2026
R
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
Correct.-----Nothing wrong with the needle.-----Does spark jump a gap of 5/16" on both leads ?-----Post actual compression values...
Sep 14, 2026
tpenfield
@alldodge . . . When is the date for the 'swap meet'? You will have 2 of the happiest days of boat ownership all on the same day! :LOL:
Sep 14, 2026
starter concern
post a pic of the wiring pull the plugs to see if you have water in the cylinders
Sep 14, 2026
roscoe
Hello, this is satire. Put out by a fictitious entity that just happens to use the name of a newspaper that went out of business in...
Sep 14, 2026
redneck joe
reacted to
in the thread
with
Like
Sep 14, 2026
redneck joe
Random
Sep 14, 2026
