P
pastorbud
reacted to
Chris1956's post
in the thread
Pipe-mounted bunk bracket?
with
Like
Check Eastern Marine in Delaware. They have a good selection of trailer hardware.
Sep 14, 2026
S
SeaRayboater95
reacted to
alldodge's post
in the thread
Milky oil
with
Like
For flushing find what ever is cheapest, your not going to put the motor under load so no issue. Do agree lower weight like 10w30, could...
Sep 14, 2026
J
Jeff J
replied to the thread
What's the word on the street about current Mercury models?
There seemed to be a lot of Tohatsu motors used on the Swamp People show. I don’t know how many true to life rigs were used. I know...
Sep 14, 2026
S
SeaRayboater95
reacted to
Scott06's post
in the thread
Milky oil
with
Like
super tech or rotella what ever is cheapest. you can drop 3 qts in and let it idle get a couple filters and gallons of oil.
Sep 14, 2026
Big Gee
reacted to
Scott Danforth's post
in the thread
RV build quality - Rant
with
Like
I really hate Forrest River RV right now The cheesy roof joists that all busted apart The cheesy reinforcement for a cabinet...
Sep 14, 2026
Maybe my turn for new boat time
can always add this to the bow to aid in docking and add this to the single engine. :p:p:p:p
Sep 14, 2026
Texasmark
reacted to
Dukedog's post
in the thread
No tach,no charging
with
Like
i'd try ebay first... ya might wanna get a part number for tha right one......
Sep 14, 2026
Texasmark
Reports from owners on here and elsewhere indicate that Tohatsu makes a great engine.....Maybe that's why Merc. decided to use them...
Sep 14, 2026
K
Kosmofreeze
2001 Volvo Penta 5.0 GL cracked block
Lou - I can confirm that your description of what's going on with the raw water cooling on my 5.7 GXi-A is accurate. Even when I...
Sep 14, 2026
Scott06
Milky oil
Sep 14, 2026
S
SeaRayboater95
Milky oil
One more question for now. Do I need to remove those brand new exhaust flippers while running the engine for 30 seconds with no water...
Sep 14, 2026
C
Crosbyman
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
the cam under the mag plate has a mark (bar) it must lineup with the cam follower on the carb when the throttle is at START adjust...
Sep 14, 2026
S
stackz
15hp gamefisher wiring diagram? model 225.581508
but it is?? I mean if I put it on muffs the water intake is MUCH lower. what am I thinking about wrong? like I need to have it at least...
Sep 14, 2026
Don't know of anyone which makes them out of pipe anymore, round is hard to keep in position with a set screw or clamp under heavier...
Sep 14, 2026
Watermann
Original 1967 Styrofoam?
You can see all the little pieces separating, the old styrofoam is deteriorating. Clogging up limber holes and possibly a bilge pump in...
Sep 14, 2026
