flyingscott
reacted to
redneck joe's post
in the thread
What's the word on the street about current Mercury models?
with
Like
i had a 99(?) 15 hp Nissan (Tohatsu) and loved it.
Sep 14, 2026
flyingscott
reacted to
Scott Danforth's post
in the thread
with
Like
Mercury buys 60 HP and below from Tohatsu
Sep 14, 2026
S
SeaRayboater95
replied to the thread
Milky oil
Hmmmmm. Could it be as simple as a gasket? Well I guess I will flush it out because I wont be able to once I disassemble it. Customer...
Sep 14, 2026
S
SeaRayboater95
reacted to
Lou C's post
in the thread
Milky oil
with
Like
Just a wild guess here but if pressuring the cooling passages puts air into the actual intake manifold air passages then I’m thinking...
Sep 14, 2026
dwco5051
reacted to
redneck joe's post
in the thread
Random
with
Like
Sep 14, 2026
Lou C
Milky oil
Sep 14, 2026
S
SeaRayboater95
reacted to
nola mike's post
in the thread
Milky oil
with
Like
Guess it depends on how fast you can get a new manifold. if you flush with the engine running you're just going to end up with more...
Sep 14, 2026
nola mike
RV build quality - Rant
You pretty much have a custom RV now...but aren't you always telling us about the design life of these kinds of things? Sounds like you...
Sep 14, 2026
nola mike
Milky oil
Sep 14, 2026
D
DeepCMark58A
Random
Bait up the body and wade in a river what an idiot
Sep 14, 2026
R
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
The question is ---Does spark jump a gap of 5/16"?----Sparkplugs are not mentioned.----Sparkplugs are not involved in this test.----The...
Sep 14, 2026
C
Crosbyman
if you disconnect the vertical post and the mag cam can travel..rotate ok to aling cam mark and follower then just adjust the...
Sep 14, 2026
S
SeaRayboater95
Milky oil
Ok, found something new. Pressurized cooling system again and can hear air moving in the intake through the carb. I guess pull intake...
Sep 14, 2026
2001 Volvo Penta 5.0 GL cracked block
those block-buster 2000 kits where you attempt to draw up cold anti-freeze are not recommended. light reading in the stickies on...
Sep 14, 2026
Frame will never be an issue again. The frame mounting where the axle is attached has been addressed, along with adding the 2x2...
Sep 14, 2026
