redneck joe
replied to the thread
Maybe my turn for new boat time
yeah, but in what position on the wheel should it be mounted????
Sep 14, 2026
redneck joe
2026 NFL/CFB News and Nonsense
well if this is any indication of the penalty calling this year will get even higher scores to come...
Sep 14, 2026
M
Mc Tool
8 hp E'rude 1990 ... bonehead move
That might get the piston moving in the bore but you cant undo the damage . You should now consider your engine wounded , and hope the...
Sep 14, 2026
flashback
A steering wheel knob spinner would help this situation.
Sep 14, 2026
M
meser300
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
Do you mean that if I remove the clamp collar holding the shaft, I'll be able to disconnect it from the lever? (photo-7) Quick...
Sep 14, 2026
Berdink
'67 Holiday 18' - Make it Usable
I'm just posting an update. I've been enjoying my StarCraft. Perfect beater for my interests. The Suzuki I had on it went out in around...
Sep 14, 2026
WIMUSKY
RV build quality - Rant
No wonder it feels like the roof gives a little when walking on it....
Sep 14, 2026
Lou C
Same as with boat rebuilds you can build a better one than they will sell you. That’s why I rebuilt my old boat trailer
Sep 14, 2026
WIMUSKY
For sure a crazy day..... Highest scoring week 1 in NFL history
Sep 14, 2026
redneck joe
Sep 14, 2026
Lou C
Milky oil
I can’t see how even a leaky intake gasket would put air into the fuel/air passage in the manifold but I can see how a crack in a cyl...
Sep 14, 2026
reacted to
rolmops's post
in the thread
What's the word on the street about current Mercury models?
with
Like
They are good motors, but tohatsu is just as good for much less money
Sep 14, 2026
rolmops
Sep 14, 2026
A
Abefish0
1993 Johnson 9.9 lower cylinder wet.
I also replaced the fuel pump and took it out on the water and it ran well for almost a minute then went back to just running on the top...
Sep 14, 2026
Tim Frank
posted the thread
in
Johnson & Evinrude Outboards
Ran this engine with no oil in the gas for about 5 minutes. Yes, I know. It started to slow down ... and stopped. Did NOT actually...
Sep 14, 2026
