bajaman123
replied to the thread
Seat removal to access front of engine SL222
I've done this on a couple of Baja's and it is a major PITA to do...at least on those boats. But it DOES give you the access you need...
Sep 20, 2026
bajaman123
reacted to
alldodge's post
in the thread
2026 - Mercruiser Cool Fuel 2 Module replacement
with
Like
You don't have to to but you might want to. Once your down that far removing the 2 nuts that hole the entire assembly is easy and come...
Sep 20, 2026
bajaman123
reacted to
alldodge's post
in the thread
with
Like
Cool fuel module is mounted to bracket not the motor mount, it's just behind the mount. Remove plastic cover (push inward top and...
Sep 20, 2026
J
jlh3rd
posted the thread
an almost stepson needs some advice
in
Mercury & Mariner Outboards
So this is a late 90's Merc 60 hp 2 stroke. I've got it running great. Two issues. Tilt/trim is inop, but I believe I can replace the...
Sep 20, 2026
dingbat
Starting engines with jump box & dead house batteries
The voltage regulator regulates output of the alternator. The “boost” function on a charger is unregulated. A battery does not store...
Sep 20, 2026
J
jase34242
Thanks, okay, so I'm not going anywhere near #26. Getting the plastic front off, then removing 12 and 11 will get out of the way...
Sep 20, 2026
J
jase34242
reacted to
alldodge's post
in the thread
with
Like
No, screw 21 just holds the plastic box to the bracket, and you cannot get to it without removing the bracket item 1 Remove the 2 nuts...
Sep 20, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
Thunderbolt V question
with
Like
Never understood it either. Used a vice grips or channel locks to snap the old rotors off. Never added loctite and never had a problem
Sep 20, 2026
Sep 20, 2026
S
SeanF45
Restoring 1975 glasply 2300, bilge question...
Hey, thats a good idea with the check valve... might do that on mine.
Sep 20, 2026
S
SeanF45
reacted to
froggy1150's post
in the thread
with
Like
My cuddy was the same there was a step down toward the cabin. I laid a pvc drain down against the keel starting at the point in the bow...
Sep 20, 2026
J
jase34242
I just want to do the easiest way possible :) Will the guts come out just be removing screw 21 ? Thanks for the warning, will be paying...
Sep 20, 2026
J
jase34242
reacted to
alldodge's post
in the thread
with
Like
Sep 20, 2026
reacted to
in the thread
with
Like
Sep 20, 2026
redneck joe
iboats Football Pick 'em is back!
for any viking fans... https://www.facebook.com/share/r/1LeQSgkiz9/
Sep 20, 2026
