tpenfield
replied to the thread
Servicing my trailer bearings
It all makes sense now . . . 👍
Sep 21, 2026
rickasbury
I have it all cleaned up ready to install my new parts and will get pictures of all ready to install with new pads.
Sep 21, 2026
rickasbury
Sep 21, 2026
R
runninfarmer
reacted to
Mc Tool's post
in the thread
Light corrosion in cylinder BF130
with
Like
Oh , I wasnt aware that you actually suspected a cracked head or block , sorta changes things a bit ....but I think Id still run it...
Sep 21, 2026
M
Mc Tool
No tach,no charging
Huh , I have just had a mega run around because of a new pulse coil that had the ( colour coded ) wires and plug transposed inside the...
Sep 21, 2026
K
Kissdude
1986 70 HP Mercury Outboard
Yes I believe it is a Canadian number
Sep 21, 2026
M
Mc Tool
Sep 21, 2026
redneck joe
2026 NFL/CFB News and Nonsense
Sep 21, 2026
R
Is OA743766 a Canadian serial # ??
Sep 21, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
In addition to the engine servicing and height adjustment, I plan on doing some finish work on the Extension Bracket that I did not have...
Sep 21, 2026
J
jlh3rd
an almost stepson needs some advice
thanks, but the main question is how ...would you replace that carbon steel rod. How do you replace the bearings, seals, and...
Sep 21, 2026
J
jlh3rd
It's this diagram that you posted, not the transom. That's where the issue is. Specifically #'s 2, 3, 20. Don't need correct parts yet...
Sep 21, 2026
377 mag mpi dts Hard start after the first time
Right now I of the opinion it's lack of spark, don't know if it's the cap or not only that they are known to have issues. I start with...
Sep 21, 2026
J
JW Hall
MC1 Leaking gear oil from lower unit
Kenny....I already replaced the bushing assembly and everything seem to be in place. Still had a 1/4 inch vertical play.
Sep 21, 2026
J
JW Hall
Thank you. I'll get some acetone after the paint where the number should be and report back with some pics. Thanks again for you help.
Sep 21, 2026
