C
replied to the thread
No tach,no charging
That is shocking that a new rectifier was bad. I doubt I would even think to test the new part. Did you test the bad part? I would be...
Sep 21, 2026
C
1986 70 HP Mercury Outboard
The 70HP motor would have 3 cylinders, I would think. The 75HP powerhead may have 4 cylinders, depending on the year. I expect the...
Sep 21, 2026
Ifishmuskie2
No tach,no charging
Problem solved. Boat is now fully operational. Going on the water in 1hr. So problem was. No tach and no charging. Replaced...
Sep 21, 2026
C
an almost stepson needs some advice
Check the bottom yoke #7, top picture for play. That is usually where it is. The steering rod #9 top picture, on my '93 Merc rotted...
Sep 21, 2026
C
Having Problems with 1997 Mercury 150HP EFI V6
You need to run a 50::1 gas/oil mix until you are sure the oil injection system is working. I would test for spark first, as that is...
Sep 21, 2026
redneck joe
reacted to
WIMUSKY's post
in the thread
iboats Football Pick 'em is back!
with
Like
Over 3mins left on the clock is a lifetime for Mahones....
Sep 21, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
In addition to the engine servicing and height adjustment, I plan on doing some finish work on the Extension Bracket that I did not have...
Sep 21, 2026
tpenfield
Sep 21, 2026
JASinIL2006
Sylvan Swim Ladder Strap Replacement - Cant find this exact setup?
Same here. I made my ladder strap and it took all of 30 minutes. Very easy.
Sep 21, 2026
JASinIL2006
reacted to
airshot's post
in the thread
Ethanol!
with
Like
Well....guess I will add my experiences with E10 fuel....in the early days, I followed the fuel recommendations and changed all the fuel...
Sep 21, 2026
flashback
RV build quality - Rant
me either, they sure make a mess of your car.
Sep 21, 2026
flashback
Yep, It's clearly a shadow when I see it on my laptop. I really need to stop using the phone to look at pictures. I'll be glad when we...
Sep 21, 2026
WIMUSKY
Sep 21, 2026
T
tphoyt
I don’t miss the love bugs
Sep 21, 2026
W
wellcraftJoe
posted the thread
Spark knocking diagnosis
in
Mercury MerCruiser Sterndrives & Engines
I have a 1995 mercruiser Weber 9770s carb 5.7 mag alpha one gen 2 combo with the thunderbolt 5 ignition original engine serial number...
Sep 21, 2026
