  • alldodge
    alldodge replied to the thread jase34212.
    Sorry Bt, I guess I missed a digit on his name
  • M
    Mc Tool replied to the thread Wood stove install.
    Yeah we got told that but our logburner has been installed since 2014 and has not yet had the flue cleaned ........we only burn dry...
  • H
    Harkonnen replied to the thread R/V Port Yankee construction.
    If I could do it indoors, I would have done it indoors. :) Drought helps. I'll probably be ready to flip it again next weekend for...
  • Lou C
    Yep this one does…
  • alldodge
    The PCM must see at least 300 RPM, and ignition procedures will energize. Not sure about your motor and that's why I tried to get MUC...
  • K
    I cannot remember having a leak at that point with a new stainless shaft and bushing. Make sure the shaft does not have a scratch where...
  • A
    airshot replied to the thread Wood stove install.
    In my area, there are many auto repair shops that burn waste oil for heat in the winter. I never have a problem getting rid of my waste...
  • A
    Keep in mind that the flue pipe will need a cleaning every year. Consider your ability to clean it as you complete your design.
  • A
    airshot replied to the thread Help Identifying Boat.
    Any more pics? Paperwork should give a mfgr name or title....my guess from one Pic might be a "LoneStar....
  • Bt Doctur
    Sounds correct as long as the coil does require a ballast resistor. Some coils can run 12 volts to them like mercruiser coils and accell
  • A
    airshot reacted to matt167's post in the thread Ethanol! with Like Like.
    I run 90-93 Ethanol free in my ‘51 Plymouth for 2 reasons, the fuel pump and the carburetor. The engine itself would run on 70 octane...
  • M
    muc replied to the thread MC1 Leaking gear oil from lower unit.
    1/4” is a bit more than I remember, but it’s been a few decades since I worked on one of these. Might want to add a couple of small...
  • M
    Mc Tool replied to the thread No tach,no charging.
    shame you got a faulty one , and a spare is a cheapish bit for piece of mind . Probly the biggest issue for these things is heat . You...
  • Ifishmuskie2
    Ifishmuskie2 reacted to Mc Tool's post in the thread No tach,no charging with Like Like.
    Just to add ... what pisses me off the most is that I have been in the service/repair line of work far to long to be caught out by...
  • M
