redneck joe
replied to the thread
Stuck Steering
interesting
Sep 22, 2026
redneck joe
OMC Cobra Help (cable adjustments)
welcome to the forum. assuming you have read this, if it applies to your set up http://www.hastings.org/~stuart/cobra/
Sep 22, 2026
Lou C
https://www.marineengine.com/parts/omc-parts/omc-boat-parts.php?year=1993&hp=5.0 It's probably one of the first three in this...
Sep 22, 2026
reacted to
muc's post
in the thread
Merc 250 Verado Fuel increase
with
Like
The tilting the motor up after shutdown is covered in all the bigger engines owners manuals. But they make it sound like it's only for...
Sep 22, 2026
M
muc
Sep 22, 2026
Lou C
PS the model # is usually on the engine, a light grey sticker on either the valve cover or the thermostat housing. While your boat may...
Sep 22, 2026
Lou C
Ok I have had one of these for over 20 years and have done the adjustments myself, mine is a bit different, but I'll try to cover the...
Sep 22, 2026
P
Pmt133
reacted to
alldodge's post
in the thread
with
Like
Dealer and Mercury Tech support found the issue, it's the oil level check. Merc says when motors are shut down to raise the legs so oil...
Sep 22, 2026
Lou C
reacted to
Scott06's post
in the thread
Milky oil
with
Like
you have to have it magnafluxed or pressure tested to know. In the grand scheme of things neither are expensive. Its done this far would...
Sep 22, 2026
rickasbury
Servicing my trailer bearings
L Lol,,sorry...
Sep 22, 2026
rickasbury
reacted to
tpenfield's post
in the thread
with
Like
It all makes sense now . . . 👍
Sep 22, 2026
B
Bwillson18
posted the thread
in
OMC I/O & Inboard Engines & Outdrives
Hey, I just recently purchased a 1994 seaswirl striper 212. has a 5.0L Ford V8 and an OMC cobra outdrive. Had to do some work on the...
Sep 22, 2026
Sep 22, 2026
S
SeaRayboater95
Milky oil
Any chance those are casting ridges? All three intake holes on that head have those marks in the same place.
Sep 22, 2026
B
Boaterdan278michigan
reacted to
Horigan's post
in the thread
2008 338 Four Winns
with
Like
Ask for a pressure test and vacuum test of the drives. One of the seals may be close to failing.
Sep 22, 2026
