G
GoDawgs999
replied to the thread
Having Problems with 1997 Mercury 150HP EFI V6
Is there any cons to a oiler delete?
Sep 22, 2026
Scott06
Milky oil
That would be my thought that they are casting ridges, but you are chasing an issue , so if it were my show I would be using some tests...
Sep 22, 2026
S
Shaunds
Help Identifying Boat
Could not find tag yet, owner claims 64 might not have tag
Sep 22, 2026
JustJason
Help - Boat Accident and Insurance
You are very welcome. I won't worry about the trailer; that's a separate issue. Just provide you with the data. Region does play a role...
Sep 22, 2026
IslandExplorer
1978 Islander 22 I/O
Wow, love the diamond plate and SS floor drains you added! They probably should have done that from the factory. That looks so clean...
Sep 22, 2026
JimS123
posted the thread
Firestone Serial Number
in
Other Outboard Brands
Recently acquired what I believe is a 1946 3.6 HP Firestone outboard, made by Scott-Attwater. For the life of me I cannot find the...
Sep 22, 2026
IslandExplorer
reacted to
66Holiday924's post
in the thread
with
Like
Vinyl on the forward cabin bench. I guess they discontinued making Nautolex's glue. The Weldwood seems to be working fine.
Sep 22, 2026
A
airshot
reacted to
tphoyt's post
in the thread
Wood stove install
with
Like
I only used 45’s because the stove is centered in the room under the peak. The 45’s are together and spin on the band to any angle you...
Sep 22, 2026
A
airshot
reacted to
Mc Tool's post
in the thread
Wood stove install
with
Like
I dunno so much about log burners , but when I was running the show I had two gas fitters installing gas fires and one thing I learnt is...
Sep 22, 2026
IslandExplorer
reacted to
66Holiday924's post
in the thread
with
Like
Building the lower deck I used aluminum slats for support, and I had enough 3/4" Coosa leftover to piece in. For the flooring I'm using...
Sep 22, 2026
Berdink
Stuck Steering
I got it to pull out about an inch. I'm going to let it soak a couple days.
Sep 22, 2026
Lou C
OMC Cobra Help (cable adjustments)
There are also special tools you can buy that make the set up more accurate.
Sep 22, 2026
Stinnett21
Where to look for water leak
Sounds like cooling water from somewhere. Investigate with phone on a selfie stick.
Sep 22, 2026
Dukedog
sent... I have no clue about the motor history.... its a perfect candidate for "oiler delete"..
Sep 22, 2026
Skidude17
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
I am getting a large volume of water in my bilge. I have a '95 Mercruiser MCM 5.7L SN 0F59836545 in a 22' SeaRay. Early in...
Sep 22, 2026
