Dukedog
replied to the thread
Having Problems with 1997 Mercury 150HP EFI V6
no.....
Sep 22, 2026
M
Mc Tool
Ignition Troubleshooting - 1978 700
can you get into the switch box ? is there a circuit board you can see ? . Im just thinking that by the way you describe your...
Sep 22, 2026
WIMUSKY
iboats Football Pick 'em is back!
I'll wave as I go to the top.... Maybe... Probably not.....
Sep 22, 2026
Berdink
Would I have better chances of success with Sierra Marine? I'm thinking they at least have a lifetime warranty.
Sep 22, 2026
N
Nordin
reacted to
Berdink's post
in the thread
with
Like
Okay, switching green wires around from a known good circuit/switch on the switchbox, I get spark with all three coils. And alternating...
Sep 22, 2026
reginaldo
reacted to
Tim Frank's post
in the thread
8 hp E'rude 1990 ... bonehead move
with
Like
Thanks for the comments. 1. Compression is just over 100-PSI on both cylinders. 2. Idles well, but coughs and smokes a bit as it is...
Sep 22, 2026
S
SeaRayboater95
reacted to
Lou C's post
in the thread
Milky oil
with
Like
The lines inside the valve port could be casting ridges but the one going in between the intake & exhaust valve seat areas looks like a...
Sep 22, 2026
S
SeaRayboater95
reacted to
Scott06's post
in the thread
Milky oil
with
Like
That would be my thought that they are casting ridges, but you are chasing an issue , so if it were my show I would be using some tests...
Sep 22, 2026
IslandExplorer
reacted to
redneck joe's post
in the thread
Wood stove install
with
Like
Getting a nice small old wood stove for the shed/shop/office. Raw set up so thought i'd post pics and ask questions here. It is...
Sep 22, 2026
IslandExplorer
reacted to
Mc Tool's post
in the thread
Wood stove install
with
Like
I got one similar but with only one hot plate on top . Going to adapt it so can burn used motor oil ( I have nearly 400litres ) , but my...
Sep 22, 2026
IslandExplorer
1974 Chieftain 25 "Adventurer" Restoration
Still needs a couple last screws put in and for the divider and door cathches to be installed- but the admiral's 1953 naval crate galley...
Sep 22, 2026
Berdink
Sep 22, 2026
Lou C
Milky oil
Sep 22, 2026
M
Mc Tool
Wood stove install
My flue is straight , supported just above the ceiling and just below the roof on the inside . Flue is single 5" to the ceiling and...
Sep 22, 2026
IslandExplorer
Help Identifying Boat
Curious boat indeed. What is that horizontal ridge on the transom?? Looks almost like a welded seam on a riveted boat!? Very...
Sep 22, 2026
