K
ktholiday
posted the thread
1966(?) Starcraft Holiday – Former U.S. Army Corps of Engineers Boat Restoration
in
Starcraft Boats
Hi everyone. I recently picked up an old Starcraft aluminum boat, and I'm hoping some of the Starcraft experts can help me figure out...
Sep 23, 2026
nola mike
replied to the thread
Milky oil
Any reason not to go to your local pull a part and grab a set of heads for $50?
Sep 23, 2026
1991 sea ray 310 electrical problems
The switch on dash turns water pump on, since it didn't come on it's either bad, blown fuse/breaker, switch is bad, pump is missing...
Sep 23, 2026
Berdink
Ignition Troubleshooting - 1978 700
Likely not...The circuits are emersed in a pool of epoxy 😊
Sep 23, 2026
Berdink
reacted to
Chris1956's post
in the thread
with
Like
The switchboxes are potted with epoxy. It is very difficult to get to the innards. You might look for a new engine harness. Sierra may...
Sep 23, 2026
Berdink
Stuck Steering
Thanks, I'll check for mushrooms, and if, I'll grind the mushroom down.
Sep 23, 2026
Berdink
reacted to
Chris1956's post
in the thread
Stuck Steering
with
Like
Usually if you can rock the shift rod front to back with a pipe or monkey wrench, with penetrating oil and some rags for cleaning the...
Sep 23, 2026
redneck joe
iboats Football Pick 'em is back!
i know its only two games but...
Sep 23, 2026
Lou C
2008 338 Four Winns
I went back and looked at my Blackstone Labs result on my Cobra drive from 2015. Iron was 369 ppm water was zero. This was based on one...
Sep 23, 2026
tpenfield
2008 338 Four Winns
Doppler effect. . .
Sep 23, 2026
B
Boaterdan278michigan
2008 338 Four Winns
Thank you! Understood, we heard a strange whine at 2,000 to 2,500 rpm. Quite loud, but we thought it was the engines not being...
Sep 23, 2026
B
reacted to
tpenfield's post
in the thread
2008 338 Four Winns
with
Like
I would inquire as to when the gear oil was last changed . . . if it has been a while, then the higher readings may be explained by...
Sep 23, 2026
B
2008 338 Four Winns
That is good advice. I understand that I'll need not replace or repair certain systems during my ownership. I'm trying to identify...
Sep 23, 2026
B
reacted to
tpenfield's post
in the thread
2008 338 Four Winns
with
Like
Also, in your annual boat maintenance budgeting, plan on some repairs each year. My Formula 330 was 16 years old (740 hours) when I...
Sep 23, 2026
B
2008 338 Four Winns
Yes, we sampled both engines, both drives and the generator. The engine oil samples showed 2.5, 2.8 and 2.8 percent fuel in the...
Sep 23, 2026
