Captain Caveman
replied to the thread
Help - Boat Accident and Insurance
You rock. I appreciate the time that you put into researching this and providing a detailed answer. The value that you came up with...
Sep 24, 2026
Captain Caveman
reacted to
JustJason's post
in the thread
with
Like
You are very welcome. I won't worry about the trailer; that's a separate issue. Just provide you with the data. Region does play a role...
Sep 24, 2026
Captain Caveman
reacted to
aspeck's post
in the thread
with
Like
JustJason, that is awesome information. Thanks for sharing the ins and outs of your industry.
Sep 24, 2026
Berdink
posted the thread
Sierra Marine Warranty
in
Non-Repair Outboard Discussions
I see people post often to go with Sierra Marine because they have a "Lifetime Warranty". . Has anyone ever had to do a warranty return...
Sep 24, 2026
eggs712
1985 Bayliner 2750 Ciera Sunbridge Resto
Boat ran well... mostly. 20 hours on her now, going to do the second oil change when the rubber oil pan hose arrives (hopefully easier...
Sep 24, 2026
Berdink
reacted to
jimmbo's post
in the thread
Merc switchbox : OEM VS aftermarket ?
with
Like
OEM as good as the Original Part, which of course failed. As for the other two. I don't think there is much difference, probably made in...
Sep 24, 2026
T
tasho1
reacted to
ShoalSurvivor's post
in the thread
4.3 crankshaft/housing oil leak - next steps?
with
Like
greetings all. found oil in the bilge and isolated it to the crankshaft seal or housing. Does not appear to be an oil pan issue. I...
Sep 24, 2026
Berdink
reacted to
Mc Tool's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
yeah there is something about holding the book in your hand .... its the oily finger prints all over the pages of the section pertaining...
Sep 24, 2026
Berdink
reacted to
Texasmark's post
in the thread
with
Like
On the ignition problem, I'd loosen every connection from/to the packs and once slightly loose, work the wire back and forth which will...
Sep 24, 2026
Berdink
The way the wires are crumbling as I remove them, including the wires coming from the stator, I plan on rebuilding the whole harness -...
Sep 24, 2026
Berdink
reacted to
racerone's post
in the thread
with
Like
Remove impeller from the cup.----Let sit for 24 hrs.----Post picture of it.
Sep 24, 2026
R
Rochester_Rob
posted the thread
OMC 250 hp rough idle, back fires through carb on load
in
OMC I/O & Inboard Engines & Outdrives
Hi everyone, I have a 1973 Penn Yan tunnel drive boat with an OMC 250 inboard engine. My dad bought it when I was a kid. The engine is...
Sep 24, 2026
Berdink
reacted to
redneck joe's post
in the thread
Stuck Steering
with
Like
this is the best grease out there...
Sep 24, 2026
Berdink
Stuck Steering
I'll get a picture tomorrow, but I've got it out about 2 inches so far, and it's really corroded - black rusty crap. I'll leave it be...
Sep 24, 2026
Berdink
reacted to
Chris1956's post
in the thread
Stuck Steering
with
Like
Corroded steering rods usually only occur if they are not cleaned and lubed each season. So turn the wheel so they stick out all the...
Sep 24, 2026
