Fun Times
reacted to
Lou C's post
in the thread
Fuel pressure too high, how to fix? Small block GM V8
with
Like
How to do a running test; be careful with the hose clamps watch out for leaks!
Sep 24, 2026
Lou C
replied to the thread
Sep 24, 2026
K
kenny nunez
Holley makes an adjustable fuel pressure regulator.
Sep 24, 2026
K
kenny nunez
OMC 250 hp rough idle, back fires through carb on load
You may have either a broken ot some weak valve springs. To replace them you will have to remove the manifolds. They are easy to...
Sep 24, 2026
Lou C
I would: Hook up a vacuum gauge Get some light motor oil & a squirt can Run the motor & squirt oil around the throttle shaft for the...
Sep 24, 2026
9
99yam40
check the pressure on the other one to see if it is also high.
Sep 24, 2026
redneck joe
new vinyl and possible layout change
10-4
Sep 24, 2026
redneck joe
reacted to
Scott Danforth's post
in the thread
with
Like
hit the wood with OTF radius the substrate edges you will be wrapping. get new foam 2 mill painters plastic sheeting is great between...
Sep 24, 2026
redneck joe
Boats from work.
upsell him some new bunks...
Sep 24, 2026
redneck joe
1985 Bayliner 2750 Ciera Sunbridge Resto
good looking boat.
Sep 24, 2026
redneck joe
reacted to
eggs712's post
in the thread
with
Like
Boat ran well... mostly. 20 hours on her now, going to do the second oil change when the rubber oil pan hose arrives (hopefully easier...
Sep 24, 2026
southkogs
reacted to
aspeck's post
in the thread
Happy Birthday, @Bob_VT
with
Like
Happy birthday, Bob!
Sep 24, 2026
southkogs
Happy Birthday Bob!
Sep 24, 2026
Woodonglass
Old timers formula question
It’s imperative that you pay close attention to the plywood edges. This is the problem with plywood. This is where water intrusion will...
Sep 24, 2026
E
Ericavictoria
reacted to
tphoyt's post
in the thread
Remove the linkage to make throttle cam adjustment?
with
Like
Pry it off from the back. I have seen broken ones but I have never broken one. They are pretty tough. It’s just a ball and socket.
Sep 24, 2026
