Keith7481
replied to the thread
O2 sensor replacement
Agreed, but it's very hard to get service, want to do what I can in my own, sensor is about it.
Sep 27, 2026
C
Someone else's outboard conversion fail
Gee, so many negative vibes. Put the trailer up on ramps, like when changing your oil.
Sep 27, 2026
H
havoc_squad
How are you going to service the lower unit area of the outboard? Pull it off with a hoist every time you need to access it below like...
Sep 27, 2026
P
peters715
Entire electrical system dies when under way
I wasn't clear, apologies. Reviewing the Mercruiser Service Manual 1, there is no reference to a circuit breaker. The manual covers...
Sep 27, 2026
dingbat
The circuit breaker is part of the boat, not the motor. Mine was a small, non-descript white box with a red button mounted on the...
Sep 27, 2026
B
badrano
Skwol and Revival product opinion
It's not bad, just starting to see the need to address the beginnings of rust around the cleats, drain holes, railing.
Sep 27, 2026
Lou C
Where to look for water leak
Also check the core plugs in the engine block, the clamps on the exhaust rubber hoses, Y pipe to inner transom joint This is one big...
Sep 27, 2026
JustJason
Looks like it may have been an I/O at one point? The transom has definitely been worked.
Sep 27, 2026
C
A lot of those V8 MerCruisers have a belt driven raw water pump. If may not leak when the engine is off, but leak when the engine is...
Sep 27, 2026
Lou C
Sounds good remember it's always better to diagnose before changing parts.
Sep 27, 2026
C
1990 Mercury 2.4 V6 175 - Water leaking from power head, exhaust adapter plate connection and rattle - when engine cranked dry - runs good no rattle.
I would not think that waterleaking from the powerhead base gasket area would affect running. That area also houses the cooling water...
Sep 27, 2026
Fun Times
Just to confirm, exhaust manifold or the riser is extra hot? or both...
Sep 27, 2026
Keith7481
Thanks very much I'll see if I can reach him, much appreciated!
Sep 27, 2026
K
k_petro
Removing the side panels of angler 220 wa
It did not move actually seems like stuck. I was thinking if there are any hidden screws that I cannot see
Sep 27, 2026
D
DeepCMark58A
Isn't it amazing how ignorant people are that do not know what you know?
Sep 27, 2026
