M
Mc Tool
reacted to
Chris1956's post
in the thread
Someone else's outboard conversion fail
with
Like
To be fair, the motor is just a bit low. If it was up a few inches, and you never plan to tilt it up, run it!
Sep 27, 2026
M
Mc Tool
replied to the thread
portable fuel tank quick disconnect
My main motovation was ....with both 2 and 4 stroke motors on the same boat , was to make sure one could not hook up the wrong tank...
Sep 27, 2026
M
Mc Tool
Random
who, me ? :LOL:............probly a pie and Coke
Sep 27, 2026
M
MikeSchinlaub
The trailer doesn't even go near the transom either.
Sep 27, 2026
M
MikeSchinlaub
reacted to
havoc_squad's post
in the thread
with
Like
Found this on Facebook recently of a starcraft islander/chieftain conversion for sale. 🤦♂️ This photo is is why some people shouldn't...
Sep 27, 2026
M
MikeSchinlaub
reacted to
bakerjw's post
in the thread
with
Like
I need this... That said, an Armstrong bracket would be the answer.
Sep 27, 2026
B
bakerjw
reacted to
flashback's post
in the thread
with
Like
I'm surprised the skeg is still there..
Sep 27, 2026
J
jase34242
2026 - Mercruiser Cool Fuel 2 Module replacement
Got it out.. didn't realize I needed to switch this out as an x number of years replacement .. it's about 10 years old..
Sep 27, 2026
jimmbo
Gonna need a hell of a set of Ramps to get the motor high enough to remove the Lower Unit to replace the Water Pump Impeller
Sep 27, 2026
K
k_petro
Removing the side panels of angler 220 wa
Ok I will try this
Sep 27, 2026
D
damo79
Alignment Tool for Aplha One Gen 2
I temporarily put an SS washer under the rear mounts as they were too low, and there was no way to get the engine aligned. It sits even...
Sep 27, 2026
D
damo79
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
Small update to this "little story". I changed out the 14.5x19" SS sporty prop to the same size aluminum one and tested the boat. I...
Sep 27, 2026
flashback
Work around the flange with a thin putty knife and see if you can loosen it
Sep 27, 2026
M
muc
O2 sensor replacement
I now work the parts/service counter for a big dealer, and. It never fails to amaze me that people want to install parts that rarely go...
Sep 27, 2026
Keith7481
I only touched the manifold, didn't check the riser, in hindsight, I should have. No strainer.
Sep 27, 2026
