nola mike
replied to the thread
Where to look for water leak
Actually he said it didn't leak in the water. Then said it didn't leak in muffs... Definitely needs to figure that out first
Sep 28, 2026
Engine Dies. Sputters
PCM doesn't know what the pressure is, only what it should be
Sep 28, 2026
Lou C
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Ran the generator for 25 hrs total. There are still some people out!
Sep 28, 2026
Lou C
If you can look at fuel trims when it's running that might give you some clues, also look at upstream O2 sensor voltage readings.
Sep 28, 2026
redneck joe
best way to rejuvinate your cars headlight lenses ?
my ram i finally got tired of polishing so bought aftermarket pretty cheap, they are still decent (brother has truck) my 12 year old...
Sep 28, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
How do i get this out?
with
Like
Fast orange has pumice in it. You will be scrubbing the stain off and scuffing the gel. It would be dulled when you finish. It works...
Sep 28, 2026
redneck joe
Old Ranger
if there are any floor access points, check them to ensure there is not a double layer of plywood but if it had fiberglass down on the...
Sep 28, 2026
Sprig
Mine have remained clear since I did them 5 years ago. I used Meguaires heavy duty headlight restore kit. After that I spray them with...
Sep 28, 2026
M
MikeSchinlaub
Sep 28, 2026
M
MikeSchinlaub
reacted to
Captain Caveman's post
in the thread
with
Like
Have you tried eating plant food? It might help the bush.
Sep 28, 2026
H
hl
Old Ranger
I am in middle Alabama. The floor seems to be solid; I replaced the carpet several years ago. The gelcoat is good, but the clearcoat is...
Sep 28, 2026
R
rbwhiz
reacted to
Stinnett21's post
in the thread
Propeller advice
with
Like
By "same properties" you mean the Amazon prop is a 14.5 x 19? Recommend a Turning Point 14.25 x 21 3 blade aluminum. They have a more...
Sep 28, 2026
Stinnett21
Propeller advice
Sep 28, 2026
BWR1953
reacted to
redneck joe's post
in the thread
the best on the 'net, per the 'net
with
Like
looking up something for another thread and note where AI has directed me to. I guess not all AI is wrong...
Sep 28, 2026
muskyfins
I have a scanner. I'll scan ASAP. How do the cats play into the fuel system? Off hand do you know if the ECM outputs fuel pressure to...
Sep 28, 2026
