R
rbwhiz
reacted to
jimmbo's post
in the thread
Propeller advice
with
Like
Diameter and Pitch are only part of what makes a Prop. Blade Area, Blade Shape, Constant vs, Progressive Pitch, Cup, and Rake are also...
Sep 28, 2026
replied to the thread
Propeller advice
It's the prop I ran on my 2002 searay with the same motor/drive
Sep 28, 2026
H
Harkonnen
R/V Port Yankee construction
Fair. Except that it is no resin, it is a used resin bucket I store screws in. And it's no dumbbell, it's a weight for holding things in...
Sep 28, 2026
jimmbo
Propeller advice
Sep 28, 2026
R
rbwhiz
Propeller advice
What do you find different with the wider diameter vs more pitch???
Sep 28, 2026
J
jlh3rd
best way to rejuvinate your cars headlight lenses ?
check out Project Farms. He runs tests on about everything. Make your own choice.
Sep 28, 2026
Propeller advice
I recommend a 15x19 stainless Solas prop
Sep 28, 2026
P
peters715
Entire electrical system dies when under way
After replacing battery cables and battery switch I am not experiencing the problem now. I can run the trim, blower and sump pump...
Sep 28, 2026
S
SeaRayboater95
Milky oil
Well, the one I scavenged pressure tested good. Just getting them cleaned up and ready to install. Glad that's over. Going to lap the...
Sep 28, 2026
B
bakerjw
Old Ranger
I've seen a lot of Ranger boats with large glitter metallic surfaces. Until now, I'd never contemplated how they produced such a finish...
Sep 28, 2026
B
bakerjw
reacted to
redneck joe's post
in the thread
Old Ranger
with
Like
if there are any floor access points, check them to ensure there is not a double layer of plywood but if it had fiberglass down on the...
Sep 28, 2026
Old Ranger
Gel doesn't peel. Clearcoat does
Sep 28, 2026
Park under cover or cover HL when parked and they stay clear
Sep 28, 2026
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Looking at the 20' elevation (low tide) where I'm at.....
Sep 28, 2026
nola mike
reacted to
alldodge's post
in the thread
RV build quality - Rant
with
Like
Ya going to remove the OEM logo's?
Sep 28, 2026
