C
Crosbyman
replied to the thread
Fuel leakage problem.
alhthoug it is a possibility that the cork is saturated extensive testing by user " TUBBS" on AOMCI over several years of soaking cork...
Sep 29, 2026
tpenfield
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Oil change day . . . I got the starboard engine done, on to the port engine . . . With 11 qts of oil in each engine, it really comes...
Sep 29, 2026
L
Luray Lou
posted the thread
Signature 240 Helm seat failure
in
Chaparral Boats
I have a 2006 Signature 240 I just purchased and the helm seat is supposed to fold flat. The release mechanism is jammed and it doesn’t...
Sep 29, 2026
WIMUSKY
2026 NFL/CFB News and Nonsense
😂 https://www.facebook.com/share/r/1EoHV58hxm/
Sep 29, 2026
E
ejput
2001 Mercruiser 5.7 EFI/TBI Scan Tool
Fantastic tutorial, can't wait to try it out!! Thanks!
Sep 29, 2026
A
airshot
While it might work properly, does the float...float...they often become saturated with fuel or get a pin hole in the case of brass...
Sep 29, 2026
C
97 Johnson 130 Tilt banging when going up and down
Gee, if grease doesn't fix it, the second choice would be the PTT motor slipping while driving the pump. I do not know if that is...
Sep 29, 2026
C
Propeller advice
Try the Turning Point in 21P. They are pretty high performance and hold the water pretty good. They are also cheap enough. Different...
Sep 29, 2026
S
saltchuckmatt
reacted to
dingbat's post
in the thread
Idles 1000rpm in neutral and runs a litte rough
with
Like
My 200 hp Ocean Pro idles @ 800 in gear, ~900 neutral and 1,250-1,300 on a hose. The word "smooth" has never been used to describe...
Sep 29, 2026
S
saltchuckmatt
Appears to be binding, has it been greased properly? Tilt tube nut, check it's torque value.
Sep 29, 2026
G
George 1975montauk 17
1988 70 HP Johnson Cooling System Modification (+ Additional Work)
Hey, hopefully you are still on this forum. Because I can’t find anything regarding this motor and of course I don’t know the exact...
Sep 29, 2026
dingbat
Sep 29, 2026
redneck joe
Love this https://www.facebook.com/share/r/1DMNFmr3S9/
Sep 29, 2026
Berdink
reacted to
Chris1956's post
in the thread
1978 Mercury 70hp Adding Power Tilt Trim
with
Like
I think you need a PTT unit from the 3 cylinder Mercs starting in the early 70s. I think you can also use one from the 4 cylinder 50HP...
Sep 29, 2026
Scott06
Ok a question about points systems….
did the old coil fail and ohm test of primary and secondary side? Spark gap test of out put? just wondering how you landed on the coil...
Sep 29, 2026
