Berdink
reacted to
Scott Danforth's post
in the thread
Gelcoat cracking
with
Like
the best route and often the shortest route is the one that seams the most daunting. wood is structural, epoxy wood filler is just...
Sep 29, 2026
Berdink
reacted to
in the thread
Gelcoat cracking
with
Like
You need to grind down to good glass, then build back up. Suggest you flag your thread and have moved to the restoration forum Also...
Sep 29, 2026
jimmbo
replied to the thread
Propeller advice
It is on the Band, around the Upper Gear Case
Sep 29, 2026
R
rbwhiz
Propeller advice
I want to say mine is 1.62? That comes to mind. I'll try and look it up again.
Sep 29, 2026
R
rbwhiz
reacted to
Chris1956's post
in the thread
Propeller advice
with
Like
Try the Turning Point in 21P. They are pretty high performance and hold the water pretty good. They are also cheap enough. Different...
Sep 29, 2026
FLATHEAD
reacted to
WIMUSKY's post
in the thread
Just thought I'd share a nice photo.
with
Like
Went out with the wife today. Could be the last time this year....
Sep 29, 2026
WIMUSKY
reacted to
Mc Tool's post
in the thread
with
Like
Why , what did she do ?:LOL:
Sep 29, 2026
S
saltchuckmatt
97 Johnson 130 Tilt banging when going up and down
I would pull that pin and clean/lube it. Salt water motor. Torquing the tube nut solved my noise on my E-tec. Noise was slightly...
Sep 29, 2026
jimmbo
1968 Sportwin water trickle top of power head
Everything has a Place, and Everything all over the Place
Sep 29, 2026
C
The PTT system needs to pivot a bit on the upper and lower pins. Maybe it is binding on them?
Sep 29, 2026
aspeck
reacted to
WIMUSKY's post
in the thread
2026 NFL/CFB News and Nonsense
with
Like
😂 https://www.facebook.com/share/r/1EoHV58hxm/
Sep 29, 2026
JonBoat55
reacted to
in the thread
How do i get this out?
with
Like
contains oxalic acid
Sep 29, 2026
V
vasilios
posted the thread
Mercruiser EC Exhaust Manifold Overheat - Help Please
in
Mercury MerCruiser Sterndrives & Engines
Hey, looking for some insight from the Gurus I have a 2018 Cruiser yacht with twin Mercruiser Seacore 377 EC Closed-loop cooling...
Sep 29, 2026
P
pspagna
Has a new steering cable and tube was greased. The noise is coming from the bottom pin where the bracket on the transom rotates where...
Sep 29, 2026
Lou C
Ok a question about points systems….
Well that’s interesting it still tested fine with the resistance test but when I hooked up the spark tested to the plug wire the spark...
Sep 29, 2026
