replied to the thread
2001 Mercruiser 5.7 EFI/TBI Scan Tool
Don't know of any Merc which used the MEFI 5, it was only used Indmar and VP
Sep 29, 2026
M
Mc Tool
Wood stove install
I just gotta say .... I dont see anything ugly about a bit of flue , its part of the whole pot belly burner thing ......as long as it...
Sep 29, 2026
Milky oil
Push rods normally change when lifters do
Sep 29, 2026
C
Crosbyman
Engine dies under load
if hand pumping helps sounds like a bad fuel pump + hand pump not getting hard it may indicate a inlet needle not closing...
Sep 29, 2026
A
AlkyElto
updated their
status
1959 GALE Sovereign 35 hp ..I Need 2 side covers ( cowls ) .. Help !! Appreciate anything you have Alky Elto
Sep 29, 2026
A
AZ_J
posted the thread
in
Johnson & Evinrude Outboards
Hello all, Went through and did the annual maintenance. Got the boat out this past Saturday and from the first startup to getting to...
Sep 29, 2026
Lou C
Mercruiser EC Exhaust Manifold Overheat - Help Please
Don’t know your system but is there some kind of a control valve regulating flow to the elbow?
Sep 29, 2026
Sprig
best way to rejuvinate your cars headlight lenses ?
I want to elaborate a little on this subject. I researched it thoroughly a few years ago , even spoke to an engineer friend. Most modern...
Sep 29, 2026
B
boscoe99
Yamaha F250A 6P2 – Code 72 Above 4000 RPM After Warm-Up
That tachometer does not provide fault codes. You will need either YDIS of the winky blinky to get any codes that may be set.
Sep 29, 2026
BWR1953
reacted to
Mc Tool's post
in the thread
Just thought I'd share a nice photo.
with
Like
Why , what did she do ?:LOL:
Sep 29, 2026
redneck joe
Wood stove install
and the shed is all done except the window and door trim/frames. Note, the bell is installed...
Sep 29, 2026
redneck joe
Wood stove install
here is where i want it (yes move shelf) but the collar i got is 38" and thru the roof ppe is 48" so need to think more. If i put...
Sep 29, 2026
C
Crosbyman
1968 Sportwin water trickle top of power head
yep 9622a paid 50$ cdn about 35U$ stuck rings came loose after a week of soaking and poking ... motor even had the...
Sep 29, 2026
redneck joe
2026 NFL/CFB News and Nonsense
saw that. agree the call was bad but also can see how it might have been called. Should have challenged it if possible and if not i...
Sep 29, 2026
E
ejput
I did see this on another post and would like to know if I have anything to worry about by using the paperclip? It looks like I can...
Sep 29, 2026
