redneck joe
replied to the thread
Wood stove install
i have and will be doing additional work with cement board and aluminum tube. This is just placement atm.
Sep 29, 2026
S
saltchuckmatt
Engine dies under load
2 different problems. No shortcuts unfortunately. Fuel pumps both have the same reliability...your vro probably just needs a new...
Sep 29, 2026
tpenfield
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
OK I discovered something weird . . . . . I usually look at the round gauges (Veratron) for engine hours and today noticed they were at...
Sep 29, 2026
S
saltchuckmatt
reacted to
Crosbyman's post
in the thread
with
Like
if hand pumping helps sounds like a bad fuel pump + hand pump not getting hard it may indicate a inlet needle not closing...
Sep 29, 2026
tpenfield
Mercruiser EC Exhaust Manifold Overheat - Help Please
Here is a link to one of my several threads on Mercruiser Seacore cooling issues . . ...
Sep 29, 2026
A
AZ_J
Does anyone recommend any troubleshooting ideas to help me determine one or the other? And the fuel pump is a VR02 oil injected pump...
Sep 29, 2026
reacted to
tpenfield's post
in the thread
with
Like
Sep 29, 2026
T
tphoyt
Wood stove install
It will need to be a distance from the wall. Might want to check your local code.
Sep 29, 2026
tpenfield
Sep 29, 2026
tpenfield
BTDT . . . I had (past tense) a Cruisers Yacht 338 with the Mercruiser 6.2L Seacore engines. . .{converted it to outboards} . . . I...
Sep 29, 2026
First need serial number? When was impeller last replaced? Might be the poppet valve
Sep 29, 2026
N
needin some help
Fuel leakage problem.
I filled the bowl with gas, let the float float did lose some gas due to evaporation, took the float out and laid it on. A paper towel...
Sep 29, 2026
N
needin some help
Here are a few pics.everything look o.k.?
Sep 29, 2026
N
needin some help
The primer bulb never gets " hard " but it does get stiff.
Sep 29, 2026
E
ejput
2001 Mercruiser 5.7 EFI/TBI Scan Tool
great, I'll use the clip
Sep 29, 2026
