  • Scott Danforth
    Scott Danforth replied to the thread Propeller advice.
    he stated he is spinning an unknown quality amazon prop at that RPM and that it "absolutely jumps on plane". I suspect that the Amazon...
  • SHSU
    SHSU reacted to 66Holiday924's post in the thread 1978 Islander 22 I/O with Like Like.
    I added edge trim to finish my interior bench piece. I couldn't find trim the exact size I needed... This is 1/2" and my piece is 1/2"...
  • Scott06
    Scott06 replied to the thread bravo 1 u joint.
    I would recheck the alignment several times and rotate the coupler 90 deg 4 times to check alignment through the arc of coupler...
  • Scott06
    Scott06 replied to the thread Milky oil.
    I cannot confirm from here with 100% confidence but i think so. Best way is to research your casting number to a 4.3 engine family...
  • Stinnett21
    Stinnett21 replied to the thread Propeller advice.
    My 5.0 MPI alpha drive (1.62 ratio) is turning the prop I mentioned in post #2 at 4920 rpm. My top range is 5000 rpm so that's dialed...
  • JonBoat55
    JonBoat55 reacted to dingbat's post in the thread old pictures with Like Like.
    My Great, Great, Great Grandfather 9th West Virginia Infantry Regiment.....1861-1864
  • L
    Been a while since I've posted on this thread. I haven't changed the gimble bearing on this boat in my ownership and I don't know when...
  • redneck joe
    redneck joe reacted to aspeck's post in the thread old pictures with Like Like.
    My dad pulling us around in the yard behind the old Wheel Horse garden tractor. The family ...
  • P
    Pmt133 reacted to redneck joe's post in the thread Just thought I'd share a nice photo. with Like Like.
    a few years back, my assistant Fred trying to help with the house re-plumb. his first experience with pex so i cut him some slack...
  • C
    Chris1956 replied to the thread Porter Cable BN200.
    I would expect Porter-Cable to have a rebuild kit for that nailer. I bought a rebuild kit for my Senco FR framing nailer at Amazon.
  • S
    SeaRayboater95 reacted to Lou C's post in the thread Milky oil with Like Like.
    If that’s what the FSM says then yes. One other resource would be a GM shop manual since it’s a GM engine. The only ones I’ve ever...
  • Lou C
    Lou C replied to the thread Milky oil.
  • aspeck
    aspeck replied to the thread old pictures.
  • S
    SeaRayboater95 replied to the thread Milky oil.
    So can I assume that no response from you guys means 20ft/lbs is the correct torque on the valves?
  • T
    tphoyt replied to the thread old pictures.
    Me my sister and grand parents Probably 68.
