reacted to
Scott06's post
in the thread
2013 Stingray 198lx engine options
with
Like
No any 96 and up 8 bolt intake vortec will work. I did the same project on a 2004 sea ray the 090M block casting 4.3 uses some metric...
Oct 4, 2026
C
posted the thread
Are pontoons easy to repair by welding?
in
Pontoons
My neighbor's 24 footer had the port pontoon damaged in a storm. The front of the pontoon was torn open. The opening is say 12" long...
Oct 4, 2026
FLATHEAD
replied to the thread
Just thought I'd share a nice photo.
Have not been there yet as well. I know the girl that manages the place. Daughter of a dear friend of mine.
Oct 4, 2026
B
Boaterdan278michigan
reacted to
tpenfield's post
in the thread
2008 338 Four Winns
with
Like
The problem is, and will be, that boats 15-20 years old will need a lot of work. The owner/seller may not be aware of all the things...
Oct 4, 2026
P
Pmt133
Ever have a car oil clean for long time?
We measure color in our lab as a purely esthetic property. The GC mass spec and other ancillary equipment is for everything else that...
Oct 4, 2026
P
Pmt133
reacted to
bajaman123's post
in the thread
with
Like
MANY factors contribute to the COLOR of the oil...if that is what you are basing your opinion on "clean" about. One certainly should...
Oct 4, 2026
Texasmark
reacted to
Berdink's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
I'm thinking the Stator and Trigger were original. The wires just crumbled away as I removed them. I didn't want to risk it. I bought a...
Oct 4, 2026
bajaman123
Oct 4, 2026
reacted to
Scott Danforth's post
in the thread
Porter Cable BN200
with
Like
Doing the crown molding in the house, my old Delta nailer went phhlllbbtttt, so I ended up with a Metabo from Amazon or Lowe's the...
Oct 4, 2026
Scott06
Oct 4, 2026
Ifishmuskie2
It seems like once you get 60,000 miles on them the oil is darker. After that I change the oil at 3,000 miles of use just to get more...
Oct 4, 2026
Porter Cable BN200
Oct 4, 2026
P
Pmt133
safety chain question
On our f150 the hookup for the chains is way back on the reciever and the the pin is located further out than normal. Ball sticks out...
Oct 4, 2026
R
reacted to
Lpgc's post
in the thread
with
Like
I had an '81 Mercury 3 cylinder 70hp engibe on a 14ft boat around 15 years ago. It was running rough when I bought it and I found...
Oct 4, 2026
J
jlh3rd
Pontoon defect (blemish?) on log
I agree. I had an age crack at a seam and a crack at an "M" mount on my original toons ('06). Expert welder with aluminum, no problem.
Oct 4, 2026
