S
Setzer
replied to the thread
Transducer mounting Question?
That's great for you, but I don't see how this answers my question?
Oct 4, 2026
Berdink
reacted to
Chris1956's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
There is no thermostat on that motor, right? On those motors, make sure not to overprop them, as the cooling is mostly based on the...
Oct 4, 2026
tpenfield
2008 338 Four Winns
Yes, I was thinking. . the price was a bit high . . . I've seen same boats in the $70K range . Were the mechanical and safety issues...
Oct 4, 2026
tpenfield
reacted to
Boaterdan278michigan's post
in the thread
2008 338 Four Winns
with
Like
Compromise is part of the deal, I get that. I had accepted several scratches and nasty spider cracks. I obligated myself to repair...
Oct 4, 2026
C
Oct 4, 2026
9
99yam40
Are pontoons easy to repair by welding?
just keep in mind that the tube is not normally flat, so if you have to get some proper type and thickness aluminum to lay on it to weld...
Oct 4, 2026
reginaldo
reacted to
flashback's post
in the thread
safety chain question
with
Haha
bull balls are cooler!
Oct 4, 2026
ingham01952
5.0 gxi-e Fuel Pump Issues?
hello, thank you. and you noticed a sound difference before you did this?
Oct 4, 2026
Berdink
Is there a fix for the possible overheat issue? . I'm thinking for the undersized lower unit to just not oversize the prop and to not...
Oct 4, 2026
S
SeaRayboater95
reacted to
nola mike's post
in the thread
Milky oil
with
Like
Well...I tried to double check. Manual #8 (looks like where your info came from) only shows that 20 ft lb. Manual #25 (newer models, but...
Oct 4, 2026
J
Jeff J
I agree. You will want someone very proficient welding aluminum. I can weld a lot of stuff and have welded aluminum but I would not...
Oct 4, 2026
L
Lpgc
reacted to
bajaman123's post
in the thread
Ever have a car oil clean for long time?
with
Like
MANY factors contribute to the COLOR of the oil...if that is what you are basing your opinion on "clean" about. One certainly should...
Oct 4, 2026
L
Lpgc
reacted to
Pmt133's post
in the thread
with
Like
We measure color in our lab as a purely esthetic property. The GC mass spec and other ancillary equipment is for everything else that...
Oct 4, 2026
A
airshot
Aluminum us very tricky to weld and because there are many different types of aluminum that adds more dufficulty because you need to...
Oct 4, 2026
B
2008 338 Four Winns
Oct 4, 2026
