It's Here.. It's Here !!!!!!!!!!!!!!!!!
Summer Fun
Banned
Re: It's Here.. It's Here !!!!!!!!!!!!!!!!!
yes you do can never have too much ......wayne
mattttt25
it's funny. we're all concerned over a test score and we have no idea how it's computed. it could be a simple random number generator, and we'd still be trying to figure out how to "score" better.
Summer Fun
Banned
hey matt ..it tells you how they score it and compares it to other computers.......check it out on the bottom next to score ...i'll try to post it later ...got to go snowplowing ..beback in 3hrs .....wayne
Xcusme, Or Anybody who Knows.......<br /><br />
A simple cross-over Cat5 network cable between the 2 computers will allow you to transfer files back and forth with ease.....with WinXp it's easy.
I found the transfer wizard... <br />If I Unhook my cable modem, Do I plug the modem end of the cable into my old 'puter to transfer my old addressbook,+ settings to the new 'puter ????<br />I don't have a spare cable,+ there's only 1 10/100 port on each 'puter....<br />Will this Work ???????<br />Thanks...
If I do what's stated in the above post,<br /><br />Do I start up the new 'puter...<br />Then turn on the old 'puter ?????<br /><br />I Don't want to Smoke my New Box.....
Ralph 123
tylerin - only if you are using Windows 2000 or XP. If you are using Windows ME or below any additional memory will do nothing for you and in fact may slow down your system. The older versions of windows can't manage the additional memory in an efficient manner (you can go search PCmag/ ZDlabs test results from a few years back and read the research)<br /><br />SBN - congrats on the new machine. I always keep one older machine on my home network as a backup and I synch my data to it maybe once a day. Maybe a good use for your IBM.
Ralph 123
Bondo - you need a crossover cable, or parallel port "laplink" cable, not your standard Cat 5 patch cable. <br /><br />Read this if you want to make your own or you can buy one at a store near you that carries computer gear:<br /><br /> http://www.makeitsimple.com/how-to/dyi_crossover.htm <br /><br />You can also just hook the old computer back up and email the files to yourself.
Ralph 123
Bondo PS - if you decide you want to keep that old machine around and use it to back up your data or use it as a play machine, now would be the time to create a simple home network. All you have to do is pickup a broadband rounter and you will be able to share your cable connection and allow the 2 computers to communicate (share files, etc.)<br /><br />Computer geeks had two wired types available right now for under $40 <br /><br /> http://www.compgeeks.com/products.asp?cat=NET
Hey Ralph,<br /> I Guess I'm going to try the emailing them back to myself.....<br />I'm lacking cables,+ ports.....<br />Old 'puter has 2 phone/modem ports....<br />the 10/100 card...<br />2 USBs....<br />along with printer, monitor,etc.....<br />New 'puter has 2 phone/modem ports...<br />1 10/100 network port...<br />4 USBs on the back,+ 2 more on the face....<br />along with the various others, printer, monitor, etc......<br /><br />Even if I could go USB to USB, the cables I have Aren't the Flat USB on Both ends.....<br /><br />Sometime in the Near future I hope to be setting up a small Network.....<br />3 puters... Need to network Mine as master, then the gal next door(otherside of a wall,live in a duplex), Then a line out to the Garage/Office.. about 250ft.... I want to do it All Hard-wired... Not wireless.....<br />Still have to find the Router, etc... Been looking at tigerdirect.com... Not Expensive... Looks Pretty Simple..... <br />Trick will be, Not having RoadRunner Charging me for 3 'puters on-line.....<br />Haven't decided What to do with the old 'puter after I recover the Needed Info from it.....
SpinnerBait_Nut
Still have to find the Router, etc... Been looking at tigerdirect.com... Not Expensive... Looks Pretty Simple..... <br />Trick will be, Not having RoadRunner Charging me for 3 'puters on-line.....<br />Haven't decided What to do with the old 'puter after I recover the Needed Info from it.....<br />
Bondo, I will be using this one,<br /> http://www.compgeeks.com/details.asp?invtid=DI-704P-R <br />4 puters and a printer shared.
Ya,<br />I saw that one when I used the link Ralph posted....<br />I'm pretty Sure that'll do All I need to do.....<br />There are printers at all 3 computers, so a shared printer really isn't needed......<br />But, Hey if it's there.........<br /><br />BTW, What's a KVM switch ?????
SpinnerBait_Nut
Originally posted by Bondo:<br />BTW, What's a KVM switch ?????
A KVM-switch (Keybord Video Mouse)is to connect two pc's to one set of keyboard, monitor and mouse. By hitting a button you switch from displaying/operating one or the other. Saves space, energy and money...<br />A good one is TRENDnets 200:K.
Aaaahhhh.....<br /><br />Nope I Don't need 1 of them.......<br /><br />Having All I can do to keep 1 Going....
tylerin
Thanks Ralph, I am using xp and looks quite simple to add. Sorry Bondo for stealing a bit of your thread. Congrats on the new puter there Spinner. Can't wait to see those new jokes, (preferably the poofing ones)
Hasbeen
So, with all this said, are you going to be letting it run 24/7, or are you going to shut it down at night!<br /><br />I shut mine down!<br /><br />Hasbeen<br /><br />LubeDude
That's a Whole Nother Thread.....<br /><br />I Really like the sleep mode this 1 is doing....<br />screen saver for awhile, then it's off.......<br />come over,+ touch the mouse,+ I'm Right Where I Was......<br />The old HP had issues for awhile now.... Wouldn't Stand-by.... Just started back up everytime.....<br />I'll Probably leave this 1 running.... set-up my clean ups for odd hours....
Xcusme
Outpost.com has had a sale on the Uniden line of routers and wireless gear for some time now....I bought a few pieces a week ago, all works well.<br /><br /> Outpost --Uniden Router <br /><br />Goto their site, and do a search for Uniden. On page 2 or the results, you'll see all the sale stuff. Offer is good until the beginning of March or until supplies run out.
I'm there,+ Looking.....<br /><br />FREE, With a firewall......<br />What a Deal....
