Paint color is an issue here!
drewpster
Ok me and my wife have been going around the table on this for a year. I need a tie breaker. Don't worry I won't hold anyone responsible. We have been trying to choose a paint color for the hull of our boat. As you can see in my avatar the boat has allot of freeboard. I want to use a pale yellow color (Interlux Perfection Fighting Lady Yellow). She wants to use a dark blue color (perfection Mauritius blue). My logic in my choice is that the lighter color will help obscure defects in the 30 year old hull. Even after my amateur prep work the hull will be wavy. I also want to avoid any secondary curing caused by heat in the darker colored hull.
The truth is this, I would love to use the dark blue. Sea Ray used a dark blue color on their hulls and it looks great. However my lack of confidence in my prep makes me go light yellow. And print through could be a problem.
Is secondary curing a problem in darker hulls?
Is a darker color a huge challenge in old hulls like ours?
Should an amateur like me stick will the safer pale yellow?
Gimme some thoughts you guys, now my Dad is in on the act, he wants the dark blue. :confused:
studlymandingo
Re: Paint color is an issue here!
You are right about the lighter color hiding the imperfections a little better. I'm not sure where you guys are planning on painting the blue; but I painted a 16' runabout for a friend a few years ago, top of the hull dark blue with the bottom of the hull white. Midday, the top of the hull would cook your feet!!!​
drewpster
The deck is white. The dark blue would go around the hull above the waterline. Allot of freeboard here! Big area, dark color, makes me nervous.
Tail_Gunner
Agreed light color's will work far better than dark, Fighting lady will look great on that boat,dark will turn it into a toaster in the sun, i know im almost done with just shooting a black striping, in 60 degree weather it heat's up the whole half of the hull that's sit's in the sun.
why don't you comprimize, yellow for the hull, with the black accent where the blue is now. would be a really sharpe combo. like the old Plymouth Super Bee
drewpster
That is just what I had in mind. I saw a boat somwhere that used a thin black top stripe and what I call a compass design at the end near the bow. It looked great. It made the new paint fit the old hull design really well.
Tail_Gunner
:cool: I have another boat that i am doing in Yellow with a a deep blue with a purple tint on now mix some white in the mix, and it look's pretty sporty.
Be glad your not doing a dark blue, the black that i am using is causing me real headache's, it is a beautiful finish but every imperfection is magnafied by this lovely paint called Perfection.........:eek:
there is a vintage Yacht in one of the marina's here. it's done in the light yellow w/ black accents, and just beautiful. and there's the other one that is black hull, with cream upper, and red accent around the rub rail area. that's where i got the color scheme for my present project.
Scaaty
Paint it any color ya want...then add flames!
Kevin70
AMEN, BROTHA'. Can't go wrong with flames.
drewpster
Flames?......Hmmm.......maybe for the tender.
