2002 90hp johnson idle?
seantim
when the engine is warm it idles to fast (about 1100 to 1200rpm)cold is only like 900 how do i set ? and to what rpm
Re: 2002 90hp johnson idle?
If you adjust the idle when warm, it will then idle too slow when cool so I would begin by looking at other things first. Has any work or "fiddling" been done on the engine prior to this condition. Did this just suddenly occur or did you just acquire the boat and it has always been like this? Give us something to go on!
seantim
just got the boat the engine looks brand new the owner says only about 25 hrs on it never worked on
In that case, disconnect the throttle and shift cables at the engine and start it up. If it now idles normally, the cables need adjusting. Warm idle speed should be about 700 - 750 in gear, in the water. Adjust the idle speed screw to lower the idle. However, it is rare that idle speed would be that far off on a 25 hour engine unless somebody mucked with things. I feel a full link& sync is probably in order. You need a manual for that as its far too detailed to go into here.
seantim
where is the idle screw located?
Solittle
I would agree with Silvertip on the manual - get the OEM specific to your engine rather than an aftermarket one. Fiddlin can easily get you in a worse spot than you're in now.
seantim
please tell me where the idle screw is located the model # is J90plsnf
ziemann
Idle spec should be I believe 650 +- 100. Silvertip is as always correct. I agree. Seantim, we are trying to discourage you from messing with the carbs. You will likely make maters worse. It is highly unlikely a new outboard (which this essentially is) has carbs out of adjustment. We suspect something much more simple such as poor cable or linkage adjustment.
An OEM BRP service manual is readily available on ebay for your 90. I have the same outboard (the 2005) and bought a factory service manual for peanuts.
When you get this outboard running right, it will be fantastic.
