Re: 2002 90hp johnson idle?
In that case, disconnect the throttle and shift cables at the engine and start it up. If it now idles normally, the cables need adjusting. Warm idle speed should be about 700 - 750 in gear, in the water. Adjust the idle speed screw to lower the idle. However, it is rare that idle speed would be that far off on a 25 hour engine unless somebody mucked with things. I feel a full link& sync is probably in order. You need a manual for that as its far too detailed to go into here.
