Expidia
Thread starter- Joined
- Aug 26, 2006
- 2,374
Re: Navionics . . . I'd look elsewhere . . .
Thanks, I never even thought of how the satellites accuracy can vary depending on which ones the unit is linked to.
I have two other GPS's. One is Garmin Emap handheld and the other is a TomTom Navigator version 6 that runs in my Palm Treo 600 handheld.
They both seem to read only 3 or 4 satellites at a time. I was used to the level of their accuracy as to only having to be accurate enough to give you the turn for the next exit or they only need to be within a block or so when you are driving around some neighborhood.
But on the water it's a different need for a higher level of accuracy.
Do you think a full blown radar setup will look too tacky on a 14' 9" auminum boat
On the H20 one of the pages will tell you how many satellites you have and an EPE number. This EPE number is how accurate your GPS is with the current satellites you are using. I have seen numbers as bad as 350 and as good as 15 which is feet of accuracy. Seems I get better accuracy when I have WAAS. I cant always get this satilite and when I dont have it my accuracy goes way down.
