overheat buzzer
yfz450guy
i got this boat and the over temp buzzer is not hooked up. how do i wire it into the system.
thanks.
D
DJ
Guest
Re: overheat buzzer
What kind of engine? Let us know that and I will move the post to the appropriate area.
yfz450guy
Re: overheat buzzer
1988 bayliner bass trophy. 18ft. 125hp force.
it should be in the sig. atleast it is on my puter.:confused:
D
DJ
Guest
Re: overheat buzzer
Moving to Chrysler/Force questions.
I saw that, just wasn't sure it was the same one you were having the issue with..
roadrunnr
Re: overheat buzzer
Which part of your overheat circuit is not hooked up? There are two components to this circuit. The buzzer, which should be under the dash, gets 12 volts from the ignition switch. My manual shows it to be the red/blue wire from the switch. The other wire from the buzzer gets routed back to the the terminal block on your outboards port side just behind the starter motor. My manual shows this to be an orange wire, which should be the fifth terminal from the top. This then gets connected to the thermo switch, which is installed in the cylinder head. The termo switch acts just like a light switch in your house, if the engine overheats the themo switch closes and your buzzer will sound.
Hope this helps you out. The manual I'm referencing is the actual Force manual for both 85 and 125 HP outboards. If you plan on doing your own work it would be wise to invest in a service manual. Even my Seloc manual has a pretty decent wiring diagram, but most here will recommend the Clymer manual. I found my Force manual on Ebay after being disappointed in the Seloc!
yfz450guy
Re: overheat buzzer
let me say thanks for the reply.
let me make sure i get it. i got the sending unit and the the orange wire runs to and under the dash. it ends there. the buzzer is under the dash also and the 2 wires are just hanging there.
so i hook 1 black wire to the orange wire and the other black wire to the switched 12volt on the key switch? i hope i got it right. let me know so i can get it hooked up. thanks for the replies.
baxtr
Re: overheat buzzer
yes, when the sensor closes due to over temp, it makes the connection to ground.
roadrunnr
Re: overheat buzzer
You got it right! You may want to hook up 12V to the buzzer to make sure the buzzer works. Actually just a simple 9v battery might work for that. Kind of makes you wonder if someone disconnected it because it was going off all the time???
yfz450guy
Re: overheat buzzer
thanks soo much for the help i will hook it up today. i am smart enough to figure out how to test the buzzer and yes it works. just couldn't figure out how to wire it in. thanks again guy's.
