silverbullet
- Joined
- Sep 3, 2007
- 21
My stock VP prop was an alum 3 blade 14.25x21, on a Regal 2000 5.0GXI/sx 1.6 ratio.
Subjectively, it was a dog out of the hole, though midrange punch was good and top end was 54 on gps with a couple more likely to be had. Neglected to check top speed RPM- DOH! Seemed over propped in general.
In an attempt to get some bottom end, I got a VP alum 4 blade19x14. Now its great out of the hole, planes much quicker, great midrange, top speed 50 @ 5000 rpm, no more to be had. Oddly, at idle rpm, it goes faster through idle zones... efficiency?
Question is- what might be a good option to regain some top end without loosing holeshot and planning and maybe drop 200 rpm? SS 3 blade 21p? Alum 4 blade 21p? Would these two options perform equally except for strength?
Lastly, in trying out this new 4 blade over about 15 hrs run time it flaked off some paint off of the tips of a few blades in a very irregular pattern about 1" square- not as with wear/abrasion or impact (though there were a couple of small nicks on the leading edge...)
Question- could the wifes over-trimming while doing about 30 mph to the point of a few seconds of ventilation and increased rpms "vibrate" the paint off by harmonics? Or is it more likely factory paint defect?
