1971 merc loss of power
adam89k
Motor is in tip top shape, but when under power it takes a long time to get the boat on plane and up to speed. Carbs have been done, compression is good, fuel is 50:1, tank vent is full open.
Once boat is on plane it goes like crazy, just no bottom end.
Plugs seem to get a coating off oil on them in a short period of time. Boat is a wild cat, motor and boat are a package deal since day one no mods what so ever. Motor is a 75hp.
Any ideas ????????????????????????????
Previous thks to responders. :)
Barnacle_Bill
Re: 1971 merc loss of power
Could use a little more info. Like what size motor, boat, size of prop and tach reading at WOT.
adam89k
The motor is a 75hp prop is stock no tach. Cylinders have also been scoped,
no damage what so ever.
adam89k
Sorry the boat is a wild cat, motor and boat are package deal from day on no mods what so ever.
j_martin
No none, it almost seems like a fuel problem but I have a new line on it
and everything else seems ok.
Try opening up the idle jets 1/8 turn. If you set it so it idles perfectly, it won't launch. You have to set it a little rich, maybe even advance the idle timing a bit to compensate.
hope it helps
John
