JB007Rules
Thread starter- Joined
- Oct 21, 2008
- 12
Thanks in advance for your time. I have been reading a TON of stuff on here and so far I like what I see from you smart people!!.. I have a 1990 18' yar-craft fiberglass deep v-hull fishing boat with a 90HP Merc 6 cyl outboard 2 stroke motor. Couple of general questions:
Would this boat have a fuel pump? If so what battery is it powered from? If it helps any their is a pumper/primer ball on the fuel line before it goes into the engine.
Is their a fuel filter? if so where would it be located, and how would I replace it in the future and how ofter should I replace it?
Is the water pump impeller and the water pump two different things working together, or just one thing?
Is their any regular maintenace that I should be paying attention to for the bilge pump?, what about the power tilt?
I have a tach gauge that doesn't work, how can I fix this? (the speed, voltage, and fuel gage seem to work fine)
The boat is pulling to the right, but I read the FAQ's on here and figured out how to fix it, but I snapped a socket when attempting to turn that 1/2" bolt because it's so tight... why would it be so tight and how can I loosen it up?
I hear that their is such thing as power trim, I don't have that... can I install it? If so, how much?
Right now their are about 3-4 things that clip onto the main cranking battery (bilge, starter, other pump thing and tilt motor), which makes it a pain connecting and disconnecting the battery. Should I consider installing a wiring block?
Thanks for all of your help, and don't hesitate to hit me up on PM if you'd like to go boating, I'm always doing something!
