dbkerley
Thread starter- Joined
- Apr 6, 2009
- 443
Re: Update
I got alot of the wiring done Sunday. I made a ground bar and attached it to the support that runs across the front under the dash to make it easier to land all those grounds and trace faults. I will end up with some electrolysis out of it for sure because I used copper plate for the bar and attached it to steel. Oh well - that will take years and I will have redone it again by then.
The worst part was working out the helm controls for the anchor winch. I have controls on the winch itself. However, I wanted to have them on the helm as well. I bought a DPDT illuminated 20a switch to use and wired it in. It works fine it was just trying to get my head wrapped around the polarity reversal upside down and in 90+ degree heat was tough.
The bow pulpit is now fully mounted and I can assure you there are places in that boat that were never intended for humans. There wasn't even enough room in there for my glasses.
All of the accessories are working now. Next is the motor harness, trim, and gauges. They shouldn't be bad except for the trim conversion because I never really unwired any of the other.
I also meant to mention that removing the steering wheel is a pain because the plastic it is made from is softer than the effort required to remove it.
I know that alot of this seems like run on. However, there may come a point where it might prove valuable to you as other threads have been valuable to me when something went wrong.
