phwrd
Thread starter- Joined
- Jul 30, 2007
- 294
Bought my 2nd boat, after the lessons learned on the first, decided that I couldn't take it on the water before I made sure all systems worked.
I did have enough sense to at least jump up and down on the floor, proved solid, Wiring shoot, fuel lines deteriorated,
After I bought the boat, towed it to the mechanic for at engine over-haul before i even took it home for the wife to look at.
Power head is good, compression is good, lower unit is in pieces. $ 1800 for a used replacement, installed and tested. Motor is white in color, the new lower unit is a gray-lime green primer.
Have spent a year rebuilding everything. All new wiring, all new fuel lines, fuel sender, gas-water filter, 10 micro filter in-front of the new fuel flow turbine. All new gauges, new bus and fuse blocks....
Just have spent the time and $ to make the boat feel comfortable that it isn't going to crap out on me the first time out. Oops.... steering has gotten worse as it has set, while I am doing all of the other stuff.
Took the steering apart as advised and found a busted case with rusted water coming out of it.
1989 - 140 hp Suzuki with the new lower unit, has to be removed in order to replace the steering...I took it back to the mechanic. Just don't have the tools or knowledge to replace this.
Ordered a Tele-flex No Feed Back system. Paid extra but everything I have read & every body I talked to makes it sound like the difference between power steering or not. Had a buddy in high school with a 64 ford wagon that I ended up driving too many times after he indulged in a little bit too much.
Got the call that the boat was done. Paid the guy I trust over the phone. Worked it out so that my brother would pick it up this morning.
At 10:00 am, he calls me, problem with the boat. Seems that the lower unit is leaking oil. Seems that the lower unit is cracked and oil is seeping out.
The owner is actually out of town for the week. Talked to his wife. Sounded bad. So I took off work early and went to look at it. (65 minutes away).
They have dropped the motor directly onto the lower unit. This primer was smooth and clean when I took it over there.
Now it is chipped, flaked and gouged. The lower unit is cracked in two places and someone actually tried to spray gray primer over one of the cracks, like it would seal it. The Skeg is bottomed with road rash.
The question in all of this, is how far can I or should I take this ? Have the rods been bent, those running up to the engine, enough to cause damage up there ?
Would a surveyor be of use here or should I get my insurance company involved before taking to the owner ?
I do believe that the owner will do what he can to make this right, but also like to know what my options are.
