vinyle problem
skinny dugan
I have a 1995 Pro Line 251 WA and the vinyle covering on the interior is sagging in multi locations. Any and all solutions are welcome. Skiiny
redone4x4
Re: vinyle problem
if its just sagging, it depends. is it seat cushions, or gunnels/sideboards or engine cover? sometimes you can just pop some staples, spray some upholstery adhesive between the vinyl and foam, then pull tight and staple again. Does the vinyl need to be replaced?
skinny dugan
Re: vinyle problem
No the vinyle is like new and only inside the cabin, I was thinking about commerical spray glue also.Due to the fact that it's attached to fiberglass stapling is out. I'll be pulling the boat soon and the gluing will be a spring project many thanks for the comme back. Skinny
_chris_
Re: vinyle problem
The opinion of my upholstory guy is to use contact cement, it is the closest you will get to factory glue. The spray glues just don't last as long.
jennis9
Re: vinyle problem
spray glue is dependent on the temperature - as soon as it gets heated, it will pull away.
I would suggest INJECTING contact cement in a few areas and spreading it slowly and evenly - using a new needle each time you inject to keep the holes small and invisible - go at an angle. since the interior isn't as open to the elements this could do the trick for you.
skinny dugan
Re: vinyle problem
Thanks to all, I'll be going with some kind of commercial glue and over the winter i'll look into and try some applications. Thanks once again. Tight Lines Skinny
