FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
if its just sagging, it depends. is it seat cushions, or gunnels/sideboards or engine cover? sometimes you can just pop some staples, spray some upholstery adhesive between the vinyl and foam, then pull tight and staple again. Does the vinyl need to be replaced?
No the vinyle is like new and only inside the cabin, I was thinking about commerical spray glue also.Due to the fact that it's attached to fiberglass stapling is out. I'll be pulling the boat soon and the gluing will be a spring project many thanks for the comme back. Skinny
spray glue is dependent on the temperature - as soon as it gets heated, it will pull away.
I would suggest INJECTING contact cement in a few areas and spreading it slowly and evenly - using a new needle each time you inject to keep the holes small and invisible - go at an angle. since the interior isn't as open to the elements this could do the trick for you.
Thanks to all, I'll be going with some kind of commercial glue and over the winter i'll look into and try some applications. Thanks once again. Tight Lines Skinny
