Marineizing a northstar is a stupid idea.
If you want to marineize something, marineize a Vortec 6000.
Here's a list of reason why marineizing a vortec 6000 makes way more sense.
#1. 400 HP in the vortec 6000, 300 in the northstar
#2. The vortec 6000 is ALREADY a marine motor (
http://www.gm.com/experience/techno...s/specialized/marine/2010_6000_LY6_Marine.pdf) The marine and truck motors are virtually identical. Same cams, same ignition system, same fuel system.
Only real difference is the cooling system and if you're using closed cooling, it's a NON issue.
#3. Manifolds are already available for the vortec 6000 (PCM, idmar) only real custom work would be elbow adapters.
#4. The vortec 6000 has the same bolt patern as the cave-man chev small blocks that all our boats use.
#5. the vortec 6000's are a dime a dozen. Chev is putting them in EVERYTHING now adays, and there is zero demand for these motors because they literally NEVER die. GM made these with 6 bolt mains, they're virtually indestructible.
I'm looking for a vortec 6000 to marineize right now....
