kwoolard
Thread starter- Joined
- Feb 9, 2003
- 420
1999 5.7L Mercrsuier - Alpha Gen II
History:
The last time my boat has been run in the water was early Sept. Engine has ran great since I've owned it, only minor issues that have been resolved. Since Sept. I've haven't had the time to take it out on the water so I usually will run it on the muffs once a week or every other week. Last time it was ran on the muffs was last weekend and the engine ran great, no noises at all and a smooth idle at 1500 rpms.
Today's problem:
I started the engine on the muffs and instantly had this loud sharp clacking noise that sounded like something hitting the oil pan. I immediately shut it down, engine maybe ran for 3 or 4 seconds. I've fortunately never had to hear what a blown motor or broken piston rod, etc sounds like so I don't know what the problem is. I then turned the water back on and fired it up again with the same noise, engine ran like crap and backfired through the carburetor and I shut it off immediately.
I don't know what this noise is but it is LOUD and has me worried something internally has broken apart.
A buddy of mine said that it is probably the lifters and I should run it a little longer to see if it gets better, but this noise has me paranoid and I'm afraid if I do it will damage something.
Anybody have an idea as to what this could be? Do lifters drain down like that and cause such a loud noise in the oil pan?
Thanks!
History:
Today's problem:
Thanks!
