Re: Crazy idea... lawn mower motor in a Johnny OB?
I almost forgot, I have an old 6 speed trans-axle lawn mower. I thought of getting a Jonboat and mounting it in there, the speed lever is an infinite type not a clicker. I ran the mower on blocks and held one wheel still with no effort and the other when full speed, if I could immobilize one shaft, and put a "gear reduction" setup on the other it could work. Just 3 levers to control it, F-N-R, throttle, and speed selection. But after all that ciphering, I thought, I don't need all that crap taking up space in the boat, it would be easy enough to build a custom shaft, shaft housing, with flange mounts on each end, and have that housing slide into a "cuff" so I could turn it backwards for reverse. I could find an angle drive with a built in case for oil and mount it on the other end of the drive shaft housing. With a welding machine, cutting torch, grinder and small drill press it would be a simple build for me, and I would get great satisfaction and gratification out of the build. Yea I think I will do that, I will post simple designs soon.
