motor is very cold natured any way to fix it
abner
my johnson 88 spl is very cold natured it has alot of trouble starting when cold it takes a long time to start it just turns over for ever and slowly it will start
Re: motor is very cold natured any way to fix it
exactly, what are your step by step starting procedures?? could be human error. usually is.
abner
i usually pump the primor until stiff on the fuel line then push the key in for the choke to come on and i will pump the gas one or two times and try to start it
wrong. pump the fuel line bulb till hard, now move throttle lever to 1/2 throttle, turn key to ON, now push in on key for a 3 count, holding key in, turn to start, after a 5 count let key out. it should start in just a second, if not already. pull throttle lever back. you may have to push the key once or twice to keep it running, until the motor settles.
pumping the handle does nothing, the motor does not have an accelerator pump,
Fl_Richard
Bong.... Incorrect starting procedure.
1- Pump bulb until firm
2- Press key for 3-4 seconds - allows primer to prime motor
4-Advance throttle to under 50%
3- turn key - should fire. (a bit of throttle may be needed to keep it running or press key again a few times to keep her running.
(Beat me two minutes TS)
abner
thanks i will try that next time i go out and also do yall know what wot for a 19 prop is i think thats the number for the prop thats the only number i can see on it
