Re: motor is very cold natured any way to fix it
wrong. pump the fuel line bulb till hard, now move throttle lever to 1/2 throttle, turn key to ON, now push in on key for a 3 count, holding key in, turn to start, after a 5 count let key out. it should start in just a second, if not already. pull throttle lever back. you may have to push the key once or twice to keep it running, until the motor settles.
pumping the handle does nothing, the motor does not have an accelerator pump,
