perculator
Thread starter- Joined
- Jun 10, 2009
- 70
replacing my old tach and fuel gauge and would like to add a water pressure gauge. is this a good idea? any recommendations and is it an pretty easy install?
thanks
thanks
There is no easy connection for that unless you have installed a tell tale.
You could do both after following the guidelines in the tell-tale thread, just use the tee that comes with the gauge kit and insert it a few inches from the engine outlet. http://forums.iboats.com/showthread.php?t=222677
http://www.downloadingfiles.co.uk/teleflexfiles/gauges/_Outboard W-P Kit Selection.pdf
Which is exactly why a motor without a telltale should have a water pressure gauge. Although you get an indication of overheat with the temp gauge rising, you still don't know why. A quick glance at the WP gauge tells you if it is a water pump gone south or something else. It is as valuable as any other gauge but like any gauge, you must actually look at them periodically. The WP gauge has no sender. On your engine you merely tap into the water jacket, thead the hole and screw in a 1/8 inch hose barb. Instructions come with the gauge.
thanks for the input guys........but, i think i've got another problem. all this talk about overheating got me wondering about my overheat buzzer. i've never heard mine (bought the boat last year) and reading through the motor manual it should have one (don't they normally sound when starting?).
i opened my control box and found this:
The gray wire is cut. don't know why......does anybody have a wire diagram for these control boxes?
