rangerman1
Thread starter- Joined
- Apr 18, 2010
- 4
I rebuilt my 89 XR4 and I don't want to have to rebuild it again. I want to bypass the oil pump and premix. what are the things I need to do to accomplish this task
i HAD THE BLOCK MACHINED AND DID IT MYSELF
O.K. then you know what the inside of that block looks like. Like DD say's go get the correct block off kit. You can buy the correct type at www.promarineusa.com. Download the catalog, look up the part nr in the catalog and then go back to the website, search the part nr you looked up and you will be able to order it. Many of the items they have are not easily found using their website alone.
You may have to order the O ring separately. Don't know why they sell it that way but they do.
The plug goes here -
DD is telling you to remove the alarm module because the rotational sensor won't be working and it will set the alarm off. If you don't have room on your dash for a Temp gauge then find an older module that doesn't use the rotational sensor and you can keep your temp switch alarm.
