quantumman29
Thread starter- Joined
- Jul 15, 2004
- 105
hello everyone,
as many of you have known for a few months ive been having some problems with my 1985 115 tower of power,
the original problem was the engine would run fine then die and stall 20 minutes after running,
the engine has since been worked on,heres what has been done:
all 3 carbs cleaned and rebuilt,new lower switch box installed,new water jacket,new impeller,fuel pump rebuilt,new plugs,and total link and sync.....
the ol girl starts up like shes brand new,better then ever,idles sweet,takes off like a rockett runs great for 20 mins then dies,she does start right back up again but will only get to 1500 rpm and thats it........let her cool down for an hour in the shade,she runs like a dream again.....for 20 minutes only!
heres the kick in the ***:
the engine is on a 17.5 ft. glasstream bass boat, I put a stainless steel prop on that is a 23 inch pitched prop, its 3 times heavier then the 17 inch pitch aluminum prop that was originally on the engine,
I am 100% sure that the cause of the engine stalling is caused by overheat due to the 23 inch pitch heavy stainless steel prop creating too much torque on the engine.....
also, the engine will not hit more then 4800 rpm with wot with the stainless prop.
I AM PUTTING THE ORIGINAL ALUMINUM ENGINE PROP BACK ON THE ENGINE AND CALLING IT A DONE DEAL......NO MORE FANCY UPGRADES FOR ME!!!!!
can anyone agree with my discovery that this is the cause of the stalling? and if so what is the exact reason why the 23 inch prop cant be used? and why it causes the overheating?
23 inch stainless steel prop for sale, private message me if you want it,,,
mike
mike
