1988 Rogue 2420
today, going to clean up the boat, wax it, finish some upholstery, and work on some of the other things like the cabin door.......
found that an 8 foot VHF antenna mounted on a tower is no match for a bridge.......
Thwack.....thuck....thuck...thuck.....phuck.....
have a new VHF antenna coming
Snapped one off my rinker forgetting to lower it going into the barn
New antenna installed and coax run....... Now for a decal that reads "hey, dumba$$.... put the antenna down for the bridge"
Update for today.....while soldering the pl259 connector, noticed one of the ceiling panels dropped in the center.....phuck.....
Add it to the list. The panels were held with Velcro and screws, the center screw may have pulled out. The Velcro failed.... Going to adress with some 3M adhesive.
Pulled the T-stat elbow to check the filter screen prior to the HC, only a few little grains of rust. Thats fantastic news as the last trip was 22 miles without incident.
​​​​​​​Been raining here every day. Hoping for good weather this coming weekend.
Way too close to home
fetch
with all the rain we have had because someone got twin hurricanes in the 2020 bingo......(I had severed head found in St. Pete - but that is another joke)
could not take the boat out. even if the weather was good, could not get the boat from the back yard.......Admiral got the riding lawnmower stuck in the back yard....... when you walk in the back, you sink down about 2"
so we have been cutting back Florida flora with hatches....axes....and saws.....(yes, Rush reference)
then burning it in between rain storms with large quantities of E-10 89 octane
next two purchases....... set of B7 props and a Holley 850 doublepumper
working a side job for boat money
pulled the set of B8's this past weekend and installed the B6's just to run until i get a set of B7's....... with a bunch of people the hole shot suffers with the B8's as that is slightly too much prop for the current carb setup. Buddy and his wife were supposed to join us. His wife bailed and so did our stepson.
idled from the boat ramp, around the oyster beds and under the over-pass..... as soon as i was out of the no-wake zone..... mashed the throttle.....instant on-plane and next thing I knew I was spinning 5700 RPM before I backed off the throttle ...... that is about the limit of airflow thru the carb with only 715 CFM......
need a set of B7's and a bigger carb. However if a bunch of people want to go skiing all at once...... we're set...
put about 50 miles on the boat between idling along in the no-wake zones and a couple of WOT runs from no-wake to about 50mph.... Have almost 10 hours on the motor.
with a bunch of people on the swim platform, the scuppers start to leak into the boat with waves. not enough to trip the bilge pump, however enough for me to notice when I pulled the plug at the ramp.........on the list to add seacocks
I hate public ramps where people power load
Yes, another set of props need some love
Dang, where is concrete ramps when you need them
The concrete goes only about 10 feet back, then its rocks, gravel, muck and shells. About 5 feet deep where the power loaders props are...... Then there is a spoil mound about 2 feet deep as you back up
You have the tide thing going on.
Guess don't want to go stainless because this might more it to the drive
Not to mention they run about $1700 a set vs $550 for aluminum.
Can get these repaired at General Propeller
tpenfield
Wow . . . That boat is getting expensive to operate :eek:
Bummer. . . . :(
Bummer. . . . :(
Its a BOAT...... $50 in fuel, $5 in cleaning products every use.....and averaging $75 in parts
:facepalm:
just a little update. needed to wash and wax the boat this past weekend. while at it, fired it up.
last time I dug a hole, this time, I raised the boat
working on the last cushion. this is the one that sits over the motor. I added 3 drink holders and a flip over filler cushion.
decided to go with gel vs vinyl because of the abuse
first, a thickened layer of gel to fill the imperfections. I had mixed this up to fill a few screw holes I did not use in the cabin and to fix a chip in the hull
tonight I buff the fiberglass and the stainless strip that will hold the filler cushion.
little update on the cushion.
screwing the vinyl down
pulling it tight, still got some "character lines"
1004201106_resized.jpg1004201117_resized.jpg1004201117a_resized.jpg1004201117b_resized.jpg
final mounting of the strip
adding the vent to the Magma grill
